add some noise to cables/ropes?
anicg
And VEX noise version:
// Define UI controls
float remap_uv = chramp('remap_uv', @uv.x);
float power = chf('Noise_Power');
float freq = chf('Noise_Frequency');
// Create noise
vector noiseXYZ = noise(@P*freq);
// Modify noise values
vector displace = fit(noiseXYZ, 0,1, -1, 1)*power*remap_uv;
// Apply modified noise to a points position
@P += displace;
// Visualize fade ramp on curve
@Cd = remap_uv;
Personally, I would try to use bounding box information to get curve ends, but Herman solution with UVs much nicer!
noiseWires.hipnc
  On 1/25/2019 at 7:57 PM, anicg said:
For the VEX stuff, which node should I use and past it in? thanks (I'm new)
Expand
After Copytopoints, add Attribute Wrangle and paste the vex code in. Then click on this icon (see below in the picture) to generate the parameters. The Polywire comes last.
Edited by reeson
!There is a scene file attached to my previous post with a Sepu setup and my VEX option:
It requires uvtexture SOP in "Pts and Columns" mode before this wrangle, so you have to create wrangle after uvtexture SOP!
Just use output from Attribute Wrangle "noise" node in your further network
Edited by kiryha
I use noise function a lot to randomize something or to bend geometry. The basic code is :
float noise = chf('Noise_Power');
// Create noise
// Remap and pply noise to a point position
v@ns = fit(noiseXYZ, 0,1, -1, 1)*noise;
@P  += @ns;
It will add value in the range between -1 and 1 to a point position. Each point will get individual value defined by noise parameters.
One more example, if I need to randomize the distribution of scattered points I use nose to delete them. Here is VEX delete points under noise pattern file. Instead of removepoint() you can use another function, to add/set attributes etc.
