Get one component of vector in VEX expressions
kiryha
point expression function
Returns the value of a point attribute.
Replaced by
hou.Geometry.iterPoints()
hou.Point.attribValue()
point(surface_node, point_number, attribute, index)
surface_node is a path to a surface node, for example "/obj/geo1/grid1".
point_number is the point number to read the attribute from. When instancing, you can use instancepoint to get the number of the point currently being instanced.
attribute is the name of the attribute (for example, Cd for diffuse color). Two special attributes exist: P and Pw which represent the position of the point in space (Pw allows you to access the W component of the position).
index specifies the component position in multi-component attributes such as vectors, colors, and arrays. For example, if the attribute is a color, an index value of 0 returns the red component, 1 returns the green component, and 2 returns the blue component.
Note
This function will interpolate between point values if the point number is fractional, such as 3.35
EXAMPLES
point("/obj/geo1/facet1", 3, "P", 0)
Returns the X component of point 3 of the facet1 surface node in geo1.
point("/obj/geo1/facet1", 3, "N", 2)
Returns the Z component of the normal attribute of point 3 in the
In this case, I was talking about expression in the  UI parameter (to set tx in transform sop from some attribute of some node in the scene, for example).
And I am confused about this, how does it called (parameter expressions?) and which language is used here (Hscript or VEX)...
In help it is calling hscript expressions, and it usually compute value in parameters
in case with transform sop as Noobini said above you should use point expression. For convenience you can use spare input.
in case with scatter sop if you want use @Cd for scattering uncheck Force Total Count and control density with Density Scale parameter
10 hours ago, kiryha said:
In translate X expression
point(-1, 0,  "P", 1)
The second argument (0) is a Spare Input 0 reference? What is -1?
It is point expression function http://www.sidefx.com/docs/houdini/expressions/point.html
At the first place in this function you should put number of spare input instead of a path of surface node. Just drag and drop a node from Network View to a field of spare input in Parameters tab and you get a path of this node. As spare inputs may be more then one so Spare Input 0 has number of input -1, Spare Input 1 has number of input -2 and so on
Edited by vicvvsh
