Create curveu attribute for relative to branch of L-System
Is it possible to create some kind of attribute like "curveu" that takes branching into account when creating lines with L-System. I am trying to generate polywire on the lines generated by the L-System, so that the bottom trunk will be the thickest and the tip of the branches will be thin.
Dont need a foreach, just add a resample, dont need to resample anything just make sure to check the curveu attrb. Then in a wrangle.
f@width = chramp("myRamp", @curveu);
add a polywire and use the attrb @width. You can add a fuse as well if you wish to.
Edited by Sepu
