look inside of Vellum Object DOP/guides node
and then all the nodes between CONSTRAINTS node and switch12 node, those are responsible to compute the data on your constraint geometry, so you can get them from there and include in your setup
  • Like 2
  • Thanks 1
  • 2 years later...
@mapra  @anim hello hello, I am trying to do the exact same thing, but can't make it work. Let's say I wanna extract the Stress.
I used an object merge and fed it the stretch_stress wrangle in it. Then I transfer it to my geo, promote it to point and use it in a color sop. It doesnt work.
What am I doing wrong?
Tx
EDIT: I figured it out (had to copy paste the entire network and relink some stuff....a bit messy now)
I am gonna try to delete one by one what I don't need
Edited by anbt
  • 1 year later...
Tx
Hello! Can you provide hip file please. I've got the same problem.
Edited by monolight
  • 1 year later...
I would love to use the Vellum Stretch Distance Visualization data as a color attribute at render time. I think I need this explained to me in very simple and explicit terms. Any help here would be greatly appreciated. Thanks in advance.
SOLVED. Vellum post process output Attributes tab. (face-palm)
Edited by Sub_Pixel
