aracid Posted May 31, 2006 Share Posted May 31, 2006 hey all Im trying to get dominos to fall, sounds basic i get the speed and weight really looking good until the fallen dominos start moving slightly, just enough to pop out. anyone here got an idea on how to make these things stand still once fallen? i was thinking some sort of minimum threshold in DOPS? im not too fimiliar with DOPS, I would think that there is some way that i can get certain points on my RBD POINT OBJECTS to deactivate after a certain period or to stick? thanks in advance brian dominoes_SH_05_dops_v6.rarFetching info... Quote Link to comment Share on other sites More sharing options...
craig Posted May 31, 2006 Share Posted May 31, 2006 A few notes on this: First, you can speed this up a lot by setting all the contact passes and substep values in the RBD Solver back to their defaults, and instead go to the Collisions tab, Surface subtab of each RBD Point Object node and setting the Surface Representation to Edges. This resolves penetrations in cubes and cube-like objects without all the extra steps. Second, you can get the dominos to lie still after they fall by checking for their angle of rotation, and setting those that have fallen to inactive. Or even better, you can use Houdini 8.1, which has the RBD Auto Freeze node in it, which will do this for you. Third, you have your preferences set such that each of your dominos is nearly 200 meters high, and weighs about 15 kilos. Is that really what you want? Finally, domino sims are deceptive - they aren't as simple as they seem. You can optimize them a lot by grouping together only about 10 dominos, and as they fall putting new ones into the group and removing the fallen ones. Then only solve for the ones in the group. That way, you are only comparing 10 dominos to each other, not 120 as you have now. Quote Link to comment Share on other sites More sharing options...
craig Posted May 31, 2006 Share Posted May 31, 2006 I wonder: how many posts do I need before I stop being a "peon"? Quote Link to comment Share on other sites More sharing options...
aracid Posted May 31, 2006 Author Share Posted May 31, 2006 hey craig some great points there, and just in time ;-) thanks once again brian Quote Link to comment Share on other sites More sharing options...
crunch Posted May 31, 2006 Share Posted May 31, 2006 craig said: I wonder: how many posts do I need before I stop being a "peon"? 28208[/snapback] Well I'm at 74 and still a peon. If, after this post, I am no longer a peon, then it's 75. Otherwise, it's probably something higher. Quote Link to comment Share on other sites More sharing options...
michael Posted May 31, 2006 Share Posted May 31, 2006 I think it's 100 Quote Link to comment Share on other sites More sharing options...
Rafal123 Posted May 31, 2006 Share Posted May 31, 2006 Quote I think it's 100 smile.gif yeah, hundred and something that's why I posted many posts in General to escape from peon hell Quote Link to comment Share on other sites More sharing options...
Overload Posted June 1, 2006 Share Posted June 1, 2006 Finally, domino sims are deceptive - they aren't as simple as they seem. Quote Damn right they are, but from something as dominos I learned alot about DOPs. Quote Link to comment Share on other sites More sharing options...
Jason Posted June 1, 2006 Share Posted June 1, 2006 crunch said: Well I'm at 74 and still a peon. If, after this post, I am no longer a peon, then it's 75. Otherwise, it's probably something higher. 28212[/snapback] Yeah, the posts are weigthed by sheer number of posts, not by their content. Sorry crunch. It's like politics. Quote Link to comment Share on other sites More sharing options...
Marc Posted June 1, 2006 Share Posted June 1, 2006 We can certainly arrange a more permanent stay in the peon world, if you know what I mean Quote Link to comment Share on other sites More sharing options...
Pearl Posted June 6, 2006 Share Posted June 6, 2006 Hi, I just wanted to pitch in and say that you're right, dominos aren't as easy as they look. I'm also working on dominos right now. Your thread's incredibly helpful. Thanks! And on the peon thing... so it's quantity over quality? I'm relatively new to this forum, so I'm a bit afraid to say anything dumb. Maybe it's safe to keep my number low for a while. Quote Link to comment Share on other sites More sharing options...
craig Posted June 12, 2006 Share Posted June 12, 2006 I guess it would be silly to post stuff that had no real content, just to update one's total posts. So I won't do that. Quote Link to comment Share on other sites More sharing options...
Guest silveryhat Posted June 12, 2006 Share Posted June 12, 2006 (edited) nice try buddy Edited November 16, 2006 by Marc Quote Link to comment Share on other sites More sharing options...
TheUsualAlex Posted June 12, 2006 Share Posted June 12, 2006 (edited) silveryhat said: s28540[/snapback] hhm....... I don't get it... Edited November 16, 2006 by Marc Quote Link to comment Share on other sites More sharing options...
craig Posted June 12, 2006 Share Posted June 12, 2006 Looks like a hack to me. If you look up the characters, it translates to a URL. Since it was posted by someone who joined today, I suspect it would be a bad idea to point your browser there, especially if you were running Windows. Quote Link to comment Share on other sites More sharing options...
lynbo Posted June 12, 2006 Share Posted June 12, 2006 I call B.S. Nuke em! Quote Link to comment Share on other sites More sharing options...
