Convert Mesh to fluid that stays the same size
nikolaidigital
Hi everyone,
i got a question and can't figure a way out.
Imagine a bottle, and a mesh that perfectly fits into that bottle.
I want to convert the mesh into a flip fluid and when i turn on gravity i want it to be as big as before. So my bottle is filled.
The reason why i want that, is that I have a drop coming from above and falling into that bottle. When it collides with the fluid inside the bottle, I want a little splash and then the sim is done.
How can i get a filled bottle that stays filled after I turn on the Sim.
Maybe someone got the same problem or a solution, but i can't get my head around it!
Thanks and Cheers!
If the geoemtry fits perfectly, it should keep the volume almost perfectly. Could it be that there is something wrong with the collision geometry?
Maybe you can simulate it using a flat tank and after the simulation mesh the fluid as it's inside the bottle, of course if the bottle is not in movement but static.
