cluster constraint
robertolee
Hi guys, i have been trying to learn more deeply and gain more knowledge about constraints and clusters. Do you know how to achieve this kind of effect? If i want to break some red pieces when they hit to ground can i use constraint with this effect? anyone want to show with basic setup? Thanks.
You can set up constraints pretty easy with RBD Cluster SOP and RBD Constraint Properties SOP. If you switch the Cluster Type on RBD Cluster to "Group Constraints" it sets up groups for you, so you can have different constraints for the clusters and between clusters for example.
