Masoud Posted July 1, 2019 Share Posted July 1, 2019 (edited) Hi; I tried to achieve a smooth shape and calm fire as a matches flame, but as you can see in image bellow my fire is in a crazy shape..! How could I control shape of fire to make it smooth? Any comments will be appreciated. Thanks. Edited July 1, 2019 by Masoud Quote Link to comment Share on other sites More sharing options...
3dome Posted July 1, 2019 Share Posted July 1, 2019 (edited) as a start turn off any disturbance, turbulence, shredding, sharpening, confinement, play with Temperature diffusion, maybe add a gasblur if you are still unhappy use that as a base and shape the sim from there Edited July 1, 2019 by 3dome Quote Link to comment Share on other sites More sharing options...
DaJuice Posted July 1, 2019 Share Posted July 1, 2019 This is a great tutorial for candle flame. It's not in English, but easy enough to follow along. If I remember correctly the "Timescale" setting of your pyro sim is one of the most important parameters for getting away from that campfire look. 1 Quote Link to comment Share on other sites More sharing options...
toadstorm Posted July 1, 2019 Share Posted July 1, 2019 Honestly, it doesn't make much sense to use pyro for a simple candle flame. Just make the shape procedurally out of polygons or whatever, use procedural noise / bending / etc to wobble the shape, then render it as a volume. You can always do a secondary pyro sim for smoke if you need smoke. It'll be a bazillion times faster to iterate on this way. Quote Link to comment Share on other sites More sharing options...
Atom Posted July 2, 2019 Share Posted July 2, 2019 You can also check out this thread on the topic. Quote Link to comment Share on other sites More sharing options...
Masoud Posted July 2, 2019 Author Share Posted July 2, 2019 Thanks everyone, very good tips. Quote Link to comment Share on other sites More sharing options...
