Increase FLIP viscosity with particle age?
bentway23
How would one increase FLIP viscosity based on particle age, to get a thickening/coagulating effect? My searching only found one how-to from 2012, which doesn't work in H17+. I understand setting viscosity by attribute, but it appears FLIP particles don't have an age attribute, so I'm not sure how to shoehorn one in there.
Thanks!
Hey, just use a geometry vop, bind the viscosity and multiply it with the age, and then export the viscosity. You can add another multiply with a constant to tweak values and get the result you want ! And don't forget to plug it into the particle velocity !
Cheers,
Thanks, gents!
Evan, your example was great. I replaced with viscosity wrangle with a simple f@velocity = @age * [a number] and it did just what I wanted.
Don, I missed something on yours, but I can tell the error is mine. I've got screenshots of the node trees. I can tell the Geometry VOP is added in correctly--if I crank up the offset value (the parameter I added going into the add) it does alter the viscosity--but trying to multiply the age * the bound viscosity * a parameter multiplier isn't doing anything. What did I miswire?
fliptest.hip
