bentway23 Posted August 16, 2019 Share Posted August 16, 2019 How would one increase FLIP viscosity based on particle age, to get a thickening/coagulating effect? My searching only found one how-to from 2012, which doesn't work in H17+. I understand setting viscosity by attribute, but it appears FLIP particles don't have an age attribute, so I'm not sure how to shoehorn one in there. Thanks! Quote Link to comment Share on other sites More sharing options...
DonRomano Posted August 16, 2019 Share Posted August 16, 2019 Hey, just use a geometry vop, bind the viscosity and multiply it with the age, and then export the viscosity. You can add another multiply with a constant to tweak values and get the result you want ! And don't forget to plug it into the particle velocity ! Cheers, Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted August 16, 2019 Share Posted August 16, 2019 hey, here is a file. It shows a way to make a birth & age attribute. hope this helps------ flip_age.hipnc Quote Link to comment Share on other sites More sharing options...
bentway23 Posted August 16, 2019 Author Share Posted August 16, 2019 Thanks, gents! Evan, your example was great. I replaced with viscosity wrangle with a simple f@velocity = @age * [a number] and it did just what I wanted. Don, I missed something on yours, but I can tell the error is mine. I've got screenshots of the node trees. I can tell the Geometry VOP is added in correctly--if I crank up the offset value (the parameter I added going into the add) it does alter the viscosity--but trying to multiply the age * the bound viscosity * a parameter multiplier isn't doing anything. What did I miswire? fliptest.hip Quote Link to comment Share on other sites More sharing options...
bentway23 Posted August 16, 2019 Author Share Posted August 16, 2019 Also, someone on the SideFX forums pointed out that you can add an age attribute right there on the FLIP solver. Hidden in plain sight. Quote Link to comment Share on other sites More sharing options...
Sepu Posted August 16, 2019 Share Posted August 16, 2019 Quote Link to comment Share on other sites More sharing options...
bentway23 Posted August 16, 2019 Author Share Posted August 16, 2019 Yup, someone pointed that out on the SideFX forum. Beautiful, and big and obvious and staring me in the face the whole time. Thanks! Quote Link to comment Share on other sites More sharing options...
