Is it possible per-pieces scaling?
Masoud
Hello;
In "Transform SOP" (or maybe other SOPs), is it possible to do a Per_Element scaling? I mean to scale each pieces based on it's bbox_center pivot, not based on main pivot (pivot defined in transform sop).
In 3DSMax you have several option to scale selected pieces of a geometry which is awesome ("Use Selection center", "Use Pivot point center" , ... ).
Thanks.
On 8/22/2019 at 8:38 PM, dgani said:
The standard workflow for this would be to set pscale on the points before you copy to points. If you're scaling each uniformly, you can also scale your box upstream.
Thank you "dgani", but my question was in general, I mean if you import a 3d model from other software, then you will have no copy point to use "pscale".
(As you can see in my uploaded picture, I blured image of copy point nodes...).
