demoan666 Posted August 29, 2019 Share Posted August 29, 2019 Hi everyone, I am simulating a two line of text falling from top on floor, an i would like to have the pieces just crack and not tumble all over the place, I am using glue and soft constraints, and drag force. I cant seem to get it to not fall over the place (the idea is that it should be broken but still readable) here is the file with assets: https://we.tl/t-mRlziBNRRH I would appreciate a ton if someone can help me out m. Quote Link to comment Share on other sites More sharing options...
DonRomano Posted August 29, 2019 Share Posted August 29, 2019 Try to increase the stiffness of your soft constraints, and create chunks of very strong glue constraints ! Quote Link to comment Share on other sites More sharing options...
demoan666 Posted August 29, 2019 Author Share Posted August 29, 2019 (edited) increasing the stiffness of the soft constraints makes them bounce away (my bounce setting is at 0), and i didn't quite catch what did you exactly mean by "chunks of very strong glue constraints" - i would appreciate of you can break it down a bit more. thanks a lot for the reply I got a little better result by tweaking a couple of parameters and moving the right part of the text a bit further to the right, however it's still far from ideal (most of them are settled apart from a couple of letters), here it is for your reference: https://we.tl/t-Q3ck68flC5 Is there a way i can add a wrangle snippet in the post solve section saying that if anything is moving after a certain frame to pull down its velocity? Edited August 29, 2019 by demoan666 Quote Link to comment Share on other sites More sharing options...
Midasssilver Posted August 29, 2019 Share Posted August 29, 2019 Made some changes. The soft constraints aren't getting you any thing. Increase the strength of the glue constraints, and I added some collision geometry on the sides of your RBD to keep things in place. Also, you are shooting yourself in the foot by having your text start that high up. Just let it start barely above the ground and just settle a bit. Scene01.04.hiplcScene01.04.hiplc Quote Link to comment Share on other sites More sharing options...
demoan666 Posted August 30, 2019 Author Share Posted August 30, 2019 adding additional collision objects sounds like a good idea, thanks for the tip! About letting it fall from very close to the floor won't give a hard enough impact, still working on it, let's see. Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted August 30, 2019 Share Posted August 30, 2019 (edited) On 29.08.2019 at 8:04 PM, demoan666 said: Hi everyone, I am simulating a two line of text falling from top on floor, an i would like to have the pieces just crack and not tumble all over the place, I am using glue and soft constraints, and drag force. I cant seem to get it to not fall over the place (the idea is that it should be broken but still readable) here is the file with assets: https://we.tl/t-mRlziBNRRH I would appreciate a ton if someone can help me out m. Hi, try to play with gravity dop and popwrangle dops in the DopNetwork and with timeshift sop in DOP_Import also test.mov Scene01.04_01.hipnc Edited: I've did some correction and re-uploaded the scene. Edited August 31, 2019 by vicvvsh 2 Quote Link to comment Share on other sites More sharing options...
Vlasis Posted August 30, 2019 Share Posted August 30, 2019 Hi sir i think i solved the problem and i got the desired look locked down. You can further modify. Edit: Just re link the files. Scene_01_v05_Solved.hiplc 1 Quote Link to comment Share on other sites More sharing options...
