Sign in to follow this
benttoenail
Set attribute based on current Frame and hold value
Simple problem, cannot find the solution.
I need to set an attribute based on the current frame, something like this:
if(@Cd.r >= 0.9){
   f@t = @Frame;
...and I need @t to hold that value, and not change along with the current frames.
Why I need this:  I'm trying to control the offset of animated redshift instances by starting the animation once @Cd.r passes a certain threshold.  Once the animation starts, the counter for that specific instanced object needs to start at 0, and increase along with the time slider, like so:
@f = @Frame - @t;
string frameNumber = sprintf("%g%", @f);
s@instancefile = concat("$HIP/filepath.", framenumber, ".rs");
Any idea on how to do this?
Edited by benttoenail
Share this post
Link to post
What I have done before is to pre-generate the start and end frame, then only generate a valid s@instancefile, when I am within that frame range. Use a null based geo file to reference in all other cases.
if((@Frame>@start) && (@Frame<@end)){
    int current_frame = @Frame-@start;
    s@instancefile = sprintf("myfile_%02d.rs",current_frame);
} else {
    s@instancefile = "my_blank.rs";
Edited by Atom
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
