j00ey Posted December 2, 2019 Share Posted December 2, 2019 Does anyone else have a problem panning in the viewport with H18 using a Wacom? I have an Intuos 5 Touch and my buttons are set correctly as per normal but when I try to pan it tumbles instead. I've deleted my prefs in case that was the problem but it's not... Thanks Quote Link to comment Share on other sites More sharing options...
ikoon Posted December 2, 2019 Share Posted December 2, 2019 Hi Tim, I have Intuos 4 and it works fine. I am on Windows 10, Houdini 18.0.287 I have quite an old driver 6.1.5-3 BTW I have another problem in H18 with my Wacom and Stroke SOP ... the stroke_pressure is always 1.0, although H17.5 works fine on the same computer. 1 Quote Link to comment Share on other sites More sharing options...
j00ey Posted December 2, 2019 Author Share Posted December 2, 2019 Hi Jiri Thanks for the note. I'll try other drivers and see if that changes anything. I'm currently using 6.3.17-3 and I'm also on Windows 10, H18.0.287 I just opened an old scene and I can pan but not zoom so something's definitely been switched around... I just tried the stroke SOP and I'm also getting constant 1.0 pressure - stroke_angle is constant 0.0 and stroke_tilt is constant 90.0. Likewise H17.5 works as expected 1 Quote Link to comment Share on other sites More sharing options...
ikoon Posted December 2, 2019 Share Posted December 2, 2019 Hi, thank you very much for trying the Pressure, I have just RFEd it. I will send you personal message, I can send you the driver I am using. Quote Link to comment Share on other sites More sharing options...
madebygeoff Posted January 7, 2020 Share Posted January 7, 2020 Try opening Wacom Tablet Properties and under Grip Pen / Mapping uncheck "Use Windows Ink". That should fix it. If only there was a check box somewhere you could uncheck "Use Windows" 4 1 1 Quote Link to comment Share on other sites More sharing options...
j00ey Posted January 9, 2020 Author Share Posted January 9, 2020 Thanks very much Geoff - I can't believe I didn't think of that myself! Quote Link to comment Share on other sites More sharing options...
Lutojar Posted February 1, 2020 Share Posted February 1, 2020 Hi, got the same problem - stroke_pressure is always 1.0 tried Wacom Intuos3 and Intuos5, on three diffrent computers (win 10 all of them) tried to enable and disable "use windows ink" Nothing helps 18.0.348 Problem is definitely is on houdini 18 side - 17.5 and any other software use pressure without a problem with all tablets. But not h18 Actually filled a bug to SESI on that but no reaction yet ( Quote Link to comment Share on other sites More sharing options...
ikoon Posted February 3, 2020 Share Posted February 3, 2020 Hi @Lutojar I have Intuos4 and Houdini 18.0.353 With wacom driver 6.3.38-2 I get these @stroke_pressures: - with Use Windows Ink ON ... the pressure is recorded correctly (~0.01 - 1.0) - with Use Windows Ink OFF ... the pressure is always full 1.0 I don`t even have to restart Houdini to get these two kind of behaviors ... I just toggle the "Use Windows Ink" in Wacom Tablet Properties. Quote Link to comment Share on other sites More sharing options...
Lutojar Posted February 11, 2020 Share Posted February 11, 2020 Nope, unfortunately it doesn't help in my case Hope SideFX will fix it soon Quote Link to comment Share on other sites More sharing options...
brandonY Posted March 29, 2020 Share Posted March 29, 2020 yeah same here, i thought i was going crazy. Quote Link to comment Share on other sites More sharing options...
Lutojar Posted November 27, 2020 Share Posted November 27, 2020 not fixed in 18.5 (( Quote Link to comment Share on other sites More sharing options...
cushwa Posted December 1, 2020 Share Posted December 1, 2020 On 2/3/2020 at 1:25 PM, ikoon said: Hi @Lutojar I have Intuos4 and Houdini 18.0.353 With wacom driver 6.3.38-2 I get these @stroke_pressures: - with Use Windows Ink ON ... the pressure is recorded correctly (~0.01 - 1.0) - with Use Windows Ink OFF ... the pressure is always full 1.0 I don`t even have to restart Houdini to get these two kind of behaviors ... I just toggle the "Use Windows Ink" in Wacom Tablet Properties. Expand Nice Catch Jiri Miratsky ! That worked for me. Usually I would want Window Ink Off because of other behaviors associated with Window's Ink. I didn't realize that it turned off Pressure Sensitivity in Houdini. Not good. Thanks for this tip! 1 Quote Link to comment Share on other sites More sharing options...
SmithAsani Posted January 1, 2021 Share Posted January 1, 2021 (edited) Hi... I don't have the Intuos 4 but panning and zooming worked fine on my Intuos 3 once i had set the option in the Wacom Settings Manager. I'd suggest having a look in the settings for the pen and seeing what the current setting is and see if you can change it to Pan/scroll. pcb assembly in usa Edited January 14, 2021 by SmithAsani Quote Link to comment Share on other sites More sharing options...
Kupotepo67 Posted January 18, 2021 Share Posted January 18, 2021 It has been suggested to use the Wacom Tablet Properties window to uncheck the “use Windows ink” button to fix this problem. This works for general navigation purposes BUT it turns OFF the stroke_pressure data coming from the pen. stroke_pressure attribute will just show up as 1 in the geometry spreadsheet. I just bought a XP-Pen Deco 01 A4 drawing tablet (previously used a Wacom Intuos of the A6 size). Much nicer for drawing obviously than a mouse, it works just fine for Houdini. Quote Link to comment Share on other sites More sharing options...
Eyteneyer Posted April 5, 2021 Share Posted April 5, 2021 On 1/7/2020 at 11:30 PM, madebygeoff said: Try opening Wacom Tablet Properties and under Grip Pen / Mapping uncheck "Use Windows Ink". That should fix it. If only there was a check box somewhere you could uncheck "Use Windows" Expand Thanks! Quote Link to comment Share on other sites More sharing options...
