davidyannick Posted December 18, 2019 Share Posted December 18, 2019 Is there a way in vex to make this king of circle with randomly distributed edges ? Thanks for your help CIRCLE.hiplc Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted December 19, 2019 Share Posted December 19, 2019 Do you actually want / need this in VEX, or do you just want the end result (using just SOP) Quote Link to comment Share on other sites More sharing options...
davidyannick Posted December 19, 2019 Author Share Posted December 19, 2019 On 12/19/2019 at 10:05 AM, AntoineSfx said: Do you actually want / need this in VEX, or do you just want the end result (using just SOP) Expand Using just sop will be great too I thought about vex thinking he should be easier Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted December 19, 2019 Share Posted December 19, 2019 This will merge two random adjacent primitives after each iteration. deleteEdges.hipnc 1 Quote Link to comment Share on other sites More sharing options...
flcc Posted December 19, 2019 Share Posted December 19, 2019 (edited) Here is another solution that allows to keep the prim structure. Only sop, a bit convoluted IMO. I'm sure we can probably do better I think it would be easier to use vex with the setedgegroup function. CIRCLE F.hiplcFetching info... Edited December 19, 2019 by flcc 1 Quote Link to comment Share on other sites More sharing options...
AntoineSfx Posted December 19, 2019 Share Posted December 19, 2019 (edited) On 12/19/2019 at 6:50 PM, flcc said: Here is another solution that allows to keep the prim structure. It's a bit convoluted I think it would be easier to use vex with the setedgegroup function. CIRCLE F.hiplcFetching info... Expand I'd love to see a robust solution to " a random edge selection".. I think I've seen that before with a conversion to line primitives with ConvertLines / Facet unique points, then a random selection among those primitives, and transfer back that subset as an edge group to the original geo, but I can't find a way to do this. Edited December 19, 2019 by AntoineSfx 1 Quote Link to comment Share on other sites More sharing options...
davidyannick Posted December 19, 2019 Author Share Posted December 19, 2019 Wonderful, thanks for your help !! Quote Link to comment Share on other sites More sharing options...
Librarian Posted December 19, 2019 Share Posted December 19, 2019 I have Mega Exampel ... for education. #define TAU 6.283185307179586 #define PI 3.141592653589793 addpointattrib(geoself(), "ring_id", -1); addpointattrib(geoself(), "seg_id", -10); void segment(int res_lon; float start_theta; float end_theta; int res_lat; float start_phi; float end_phi; float r_min; float r_max; int ring_id; int seg_id) { string poly_type = chs("poly_type"); float theta_step = (end_theta - start_theta) / (res_lon - 1); float phi_step = (end_phi - start_phi) / (res_lat - 1); int pt; // Keep track of last created point. // Inner surface. for (int i = 0; i < res_lat ; i++) { for (int j = 0; j < res_lon; j++) { // Calculate longitude arc point position. float theta = start_theta + theta_step * j; float phi = start_phi + phi_step * i; matrix r = ident(); vector pos = set(cos(theta), 0, sin(theta)) * r_min; vector axis = cross(normalize(pos), {0, 1, 0}); rotate(r, phi, axis); pt = addpoint(geoself(), pos * r); setpointattrib(geoself(), "ring_id", pt, ring_id, "set"); setpointattrib(geoself(), "seg_id", pt, seg_id, "set"); if (i > 0 && j > 0) { // Create a new quad. int prim = addprim(geoself(), poly_type); addvertex(geoself(), prim, pt - res_lon); addvertex(geoself(), prim, pt - res_lon - 1); addvertex(geoself(), prim, pt - 1); addvertex(geoself(), prim, pt); } } } // Outer surface. Same except r_max used and reversed vertex order. for (int i = 0; i < res_lat ; i++) { for (int j = 0; j < res_lon; j++) { // Calculate longitude arc point position. float theta = start_theta + theta_step * j; float phi = start_phi + phi_step * i; matrix r = ident(); vector pos = set(cos(theta), 0, sin(theta)) * r_max; vector axis = cross(normalize(pos), {0, 1, 0}); rotate(r, phi, axis); pt = addpoint(geoself(), pos * r); setpointattrib(geoself(), "ring_id", pt, ring_id, "set"); setpointattrib(geoself(), "seg_id", pt, seg_id, "set"); if (i > 0 && j > 0) { // Create a new quad (reverse vertex order). int prim = addprim(geoself(), poly_type); addvertex(geoself(), prim, pt); addvertex(geoself(), prim, pt - 1); addvertex(geoself(), prim, pt - res_lon - 1); addvertex(geoself(), prim, pt - res_lon); } } } // Side surfaces. for (int i = 1; i < res_lon; i++) { int prim; int surface_ptnum = res_lon * res_lat; int start_pt = i + pt - surface_ptnum - surface_ptnum + 1; // Bottom. prim = addprim(geoself(), poly_type); addvertex(geoself(), prim, start_pt - 1); addvertex(geoself(), prim, start_pt); addvertex(geoself(), prim, start_pt + surface_ptnum); addvertex(geoself(), prim, start_pt - 1 + surface_ptnum); // Top. prim = addprim(geoself(), poly_type); addvertex(geoself(), prim, start_pt + surface_ptnum - res_lon); addvertex(geoself(), prim, start_pt - 1 + surface_ptnum - res_lon); addvertex(geoself(), prim, start_pt - 1 + surface_ptnum + surface_ptnum - res_lon); addvertex(geoself(), prim, start_pt + surface_ptnum + surface_ptnum - res_lon); } for (int i = 1; i < res_lat; i++) { int prim; int surface_ptnum = res_lon * res_lat; int start_pt = i * res_lon + pt - surface_ptnum - surface_ptnum + 1; // Side A. prim = addprim(geoself(), poly_type); addvertex(geoself(), prim, start_pt); addvertex(geoself(), prim, start_pt - res_lon); addvertex(geoself(), prim, start_pt - res_lon + surface_ptnum); addvertex(geoself(), prim, start_pt + surface_ptnum); // Side B. prim = addprim(geoself(), poly_type); addvertex(geoself(), prim, start_pt - 1); addvertex(geoself(), prim, start_pt - 1 + res_lon); addvertex(geoself(), prim, start_pt - 1 + res_lon + surface_ptnum); addvertex(geoself(), prim, start_pt - 1 + surface_ptnum); } } // RING FUNCTION void ring(float min_arc; float max_arc; float h_min; float h_max; float r_min; float r_max; float skip_chance; int ring_id; float ring_seed; int num_rings; float frame){ float fixed_res = chi("fixed_res"); float step_lon = ch("step_lon")+10000*fixed_res; // Longitude resolution in meters. float step_lat = ch("step_lat")+10000*fixed_res; // Latitude resolution in meters. float theta = 0; float in_theta = 0; // ch("test_theta_step"); //start_theta float out_theta = theta + TAU; float arc_width; float arc_sep_min = radians(ch("arc_sep1")); float arc_sep_max = radians(ch("arc_sep2")); float phi = 0; float arc_h; float freq_min = ch("freq1"); //height change frequency float freq_max = ch("freq2"); float sfreq_min = ch("sfreq1"); //spin frequency float sfreq_max = ch("sfreq2"); float amp_min = ch("amp1"); float amp_max = ch("amp2"); //int seg_num = npoints(geoself()); // /(res_lon+1*res_lat+1) int seg_id = 0; float f = frame; //ch("t"); //time frame //ring logic while (1) { //seeds and mapping float seed = seg_id + ring_seed; float seed_big = fit(rand(seed+2153.5),0,1, 0, 50000); float nr_max = fit(rand(r_max), 0, 1, 0.2, 1); float ring_idf = fit(ring_id, 0, num_rings, 0, 1); arc_width = fit(rand(seed+223),0,1, min_arc, max_arc); float arc_sep = fit(rand(seed+536),0,1, arc_sep_min, arc_sep_max); // check end of circle doesn't overlap begin if (theta+arc_width >= TAU-arc_sep){ arc_width = TAU-theta-arc_sep*nr_max; // } //noise fx for height float freq = chramp("freq_ramp", rand(seed_big+8+ring_idf)); freq = fit(freq,0,1, freq_min, freq_max); float sample = (f/2)*freq; float noise = noise(sample); //height arc_h = fit(noise,0.3,1,h_min,h_max); float m = arc_h*ch("mirror"); //mirror below xz plane //noise fx for rotation int crazy_spin = chi("crazy_spin"); //crazy_spinning is seeded per segment, this causes segments overlapping float sfreq = chramp("spin_ramp", ring_idf+rand(seed_big+0.5)*crazy_spin); //spin frequency ramped on ring id sfreq = fit(sfreq,0,1, sfreq_min, sfreq_max); float sample1 = f*sfreq; float noise1 = noise(sample1); float spin_rnd = fit(noise1,0.3,1,0,1); //trig fx for rotation float spin_trig = sin(sample1); spin_trig = fit(spin_trig,-1,1,0,1); //regular rotation float spin_reg = f*sfreq; //in this case sfreq is the slope of the linear curve //rotation float amp = fit(rand(ring_seed+1.25),0,1,amp_min,amp_max); int spin_dir = (rand(ring_seed+11) > 0.5) ? 1 : -1; amp *= spin_dir; //clock and counterclock turn float w; int spin_type = chi("spin_type"); if (spin_type == 0){ w = amp*spin_reg/5; // /5 is for keeping rotational speed similar to other types } if (spin_type == 1){ w = amp*spin_rnd; } if (spin_type == 2){ w = amp*spin_trig; } in_theta = w+amp; //+amp gives a in_theta offset foreach ring even when rotation is disabled // Proportional longitude resolution. float arc_width_length = r_max * radians(arc_width)*10; int res_lon = max((int) (arc_width_length / step_lon), chi("min_res1")); // Proportional longitude resolution. float arc_h_length = r_max * radians(arc_h)*10; int planar = chi("planar"); //flat rings int res_lat = max((int) (arc_h_length / step_lat), chi("min_res2"))*(1-planar)+planar; //creation if (rand(seed+1563.9) > skip_chance ) { segment(res_lon, in_theta+theta, in_theta+theta+arc_width, res_lat, phi-m, phi+arc_h, r_min, r_max, ring_id, seg_id); } theta += arc_width+arc_sep; // arc separation seg_id +=1 ; if (theta>= out_theta) break; } } float min_arc = radians(ch("arc1")); float max_arc = radians(ch("arc2")); float min_h = radians(ch("height1")); float max_h = radians(ch("height2")); float r_min = ch("r1"); float r_max = ch("r2"); float skip_chance = ch("skip_chance"); //chance to make a hole in ring float frame = @Frame; // ENTIRE RING SYSTEM int num_rings = chi("ring_count"); float ring_seed = ch("seed_ring"); float r_depth_min = ch("r_depth1"); float r_depth_max = ch("r_depth2"); float r_depth_seed = ch("r_depth_seed"); float off_min = ch("ring_off1"); float off_max = ch("ring_off2"); float r_off_seed = ch("ring_off_seed"); for (int i=0; i<num_rings; i++) { float r_depth = fit(rand(i+r_depth_seed+222),0,1,r_depth_min,r_depth_max); float r_off = fit(rand(i+r_off_seed+.5),0,1,off_min,off_max); ring(min_arc, max_arc, min_h, max_h, r_min, r_max, skip_chance, i, ring_seed, num_rings, frame); r_min = r_max+r_off; r_max = r_min+r_depth; ring_seed *=1.235684; } 2 Quote Link to comment Share on other sites More sharing options...
Noobini Posted December 20, 2019 Share Posted December 20, 2019 (edited) here's my go...does not rely on existing (discrete) segments to make cuts, does not merge and therefore no interpolation, the cuts are exactly where they are. Will work even with extremely thin cuts. alright alright, exact is a dirty word...who knows what Boolean is doing behind the scene but I'll place blind trust in boolean to its job. vu_RandomPieCuts.hiplcFetching info... Edited December 20, 2019 by Noobini 3 Quote Link to comment Share on other sites More sharing options...
