you can't compare anrold to a only-gpu renderer.. also arnoldGPU is under no obligation to compete with it.
arnoldCPU is easy-to-use heavy-duty production renderer. arnoldGPU goal is to have 100% features and flexibility of arnoldCPU.  (similar what pixar with renderman does)
redshift/octane be always faster. but arnold GPU takes no compromise in flexibility and quailty. not blackbox shader for volumes etc..
but otherwise arnoldGPU is making huge steps forwards! SSS and hair is gettign superfast, still volumes is really slow.
  • 2 weeks later...
Submit the issue to Sidefx please. Maybe you dd something wrong , or is the support of Arnold in Solaris. Solaris is commonly used to manage USD pipeline in some major studio?
Whe, doing you render test, you should also comment when kid of render time, machine spec and sampling your are using, it will make more sense...
