sipi Posted January 30, 2020 Share Posted January 30, 2020 (edited) Hey everyone! I have a simple hiRes flip simulation with a boat, but I can't mesh it properly. On random frames the middle part is disappears, and I have no idea why. I managed to figure it out it's somehow coming from the Flattening Geometry option but I couldn't solve the problem. Do you have any ideas? Edited January 30, 2020 by sipi solved Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted January 30, 2020 Share Posted January 30, 2020 Hello sipi the first thing I would try is to decrease the "Region Voxel Scale" parameter, under the "Regions" tab. Quote Link to comment Share on other sites More sharing options...
sipi Posted January 30, 2020 Author Share Posted January 30, 2020 12 minutes ago, dleonhardt said: Hello sipi the first thing I would try is to decrease the "Region Voxel Scale" parameter, under the "Regions" tab. Hi dleonhardt, Unfortunately it didn't solve it. The deafult value is 4, I tried it with even 0.2 but it didn't help. (lower numbers than that blew up the computer) Quote Link to comment Share on other sites More sharing options...
dleonhardt Posted January 30, 2020 Share Posted January 30, 2020 Could you possibly share your hip file? It's difficult to tell without looking at it. Quote Link to comment Share on other sites More sharing options...
sipi Posted January 30, 2020 Author Share Posted January 30, 2020 2 minutes ago, dleonhardt said: Could you possibly share your hip file? It's difficult to tell without looking at it. Sorry I can't share it but it's made with shelf tool, really nothing extra. Quote Link to comment Share on other sites More sharing options...
celd Posted January 30, 2020 Share Posted January 30, 2020 Hi, I came across this problem couple of times, go inside the particlefluidsurface/FLATTEN and after "flatten_geo" vop drop down a Poly Fill. This should fix your problem. 1 Quote Link to comment Share on other sites More sharing options...
sipi Posted January 30, 2020 Author Share Posted January 30, 2020 2 hours ago, celd said: Hi, I came across this problem couple of times, go inside the particlefluidsurface/FLATTEN and after "flatten_geo" vop drop down a Poly Fill. This should fix your problem. It solved. Thank you very much!!! Quote Link to comment Share on other sites More sharing options...
