China fan
microvswind
hi guys.here trouble you again.
i am trying to medelling the chinese fan,my thought is shift the primitive list as second input of wrangle node.then sue the input0 primitive vertex 1&2  and input1 primitive vertex 3&4,but i do not know how to write the vex correctly.
may you kind guys would gime me some tips or snippet code.
appreciate very much.
regards.
ChinaFan_Mic.hip
1 hour ago, anim said:
change this:
int p2 = i@parm[2];
int p3 = i@parm[0];
to this:
int p2 = i[]@parm[1];
int p3 = i[]@parm[0];
wow,you are my idol.reply so quickly and clearthank you so much.
and here again another question.how to keep undistroting  the uv texture.the texture pic and hip is attatched below.
ChinaFan_Mic.hip
You can use the circle with xyzdist() to get uv coordinates. The x coordinate can be used directly (but should be transformed by fit function to match 0 to 1). The y-value should be 0 or 1 (0 if close to circle and 1 if not).
On the other hand, if you create the surface parametrically you can set the uv-coordinates directly.
One way might be using skin from a set curves (check Konstantins example) another method maybe using two guide curves to interpolate the inbetween values.
ChinaFan_Mic_uv.hipnc
ChinaFan_Mic_uvA.hipnc
P.S: get uvxmin, uvxmax automatically
china_fan.hipnc
Edited by Aizatulin
On 2020/2/3 at 5:23 AM, Aizatulin said:
china_fan.hipnc
thank you very much Aizatulin.i have learned a lot knowledge from you.
regards.
  • 1 month later...
