How can I transfer attributes like UV, piece by piece?
Masoud
  • 1 year later...
I would actually like to have this functionality on the Attribute Transfer.
For instance when you truly want attributes to be transfered based on distance, piece-to-piece, and when the attributes are variable per point/prim for a piece.
Gonna send in an RFE..
Edit:
"This is not the Attribute Copy I am talking about. But actually transfering attributes that may vary per point, from piece to piece, (pieces that may actually vary in topology also,) based on distance, like the attribute transfer does. The piece/id parameter in any node is always a big win for me. It's the best thing ever. Much faster than a for each piece loop."
-RFE (ID# 117904)
Edited by Krion
