Deivid3D Posted March 17, 2020 Share Posted March 17, 2020 Hi everyone! I'm starting to get into Python 2.7 for Houdini Indie (17.5) before jumping into Houdini 18 with Python 3, and I've been working in a flipbook tool until now everything is being okay but now I've found that I can't recover the camera settings/flipbook settings after generating the MPlay to maintain the user settings after applying the script. I've been trying to use the 'hou.GeometryViewportCamera.stash()' to create a copy of the settings but I'm not sure how to use it and where should I recover these settings. Also when I try to use it I get this error: 'TypeError: unbound method setDefaultCamera() must be called with GeometryViewport instance as first argument (got nothing instead)' I've created a simplified version of the script that I'll be attaching down below: Quote import hou desktop = hou.ui.curDesktop() scene_viewer = desktop.paneTabOfType(hou.paneTabType.SceneViewer) viewport = scene_viewer.curViewport() #Select Camera cameras = hou.nodeType(hou.objNodeTypeCategory(),"cam").instances() selected_cam = cameras[0].path() #Set Camera comment parameter comment = "Test Comment" camera = hou.node(str(selected_cam)) #COPY THE CAMERA SETTINGS HERE<--------------------------------------- modify_cam = hou.GeometryViewport.setDefaultCamera() #Modify some parameters camera.parm("vcomment").set(comment) camera.parm("resx").set(1920) camera.parm("resy").set(1080) hou.GeometryViewport.setCamera(viewport, selected_cam) #Jump to Flipbook flipbook_options = scene_viewer.flipbookSettings().stash() flipbook_options.frameRange( (1001, 1050) ) flipbook_options.outputToMPlay(True) #flipbook_options.cropOutMaskOverlay(False) scene_viewer.flipbook(scene_viewer.curViewport(), flipbook_options) #Recover Flipbook and camera settings hou.GeometryViewportCamera.useDefaultCamera() hou.GeometryViewport.setCamera(viewport, selected_cam) If someone has any advice or idea of how would be the good approaching intro this, I'll bee really thankful. Thanks in advance to everyone. Quote Link to comment Share on other sites More sharing options...
underscoreus Posted March 17, 2020 Share Posted March 17, 2020 Hey, Don't know if this is the most efficient method (someone please correct me if there is a better way) but maybe have a look at the hou.appendSessionModuleSource? (https://www.sidefx.com/docs/houdini/hom/hou/appendSessionModuleSource.html) It's made to store variables in the HIP file itself. It's at least what I use when I need to store stuff like that. Essentially stores it as an environment variable that you can later call from anywhere in the HIP file with hou.session.variablename. Quote Link to comment Share on other sites More sharing options...
malexander Posted March 18, 2020 Share Posted March 18, 2020 useDefaultCamera and setCamera must be called on a GeometryViewport object. You have one in your script, 'viewport'. You can stash the default camera to a python object using: prev_view = viewport.defaultCamera().stash() // set your camera and flipbook viewport.setDefaultCamera(prev_view) 1 Quote Link to comment Share on other sites More sharing options...
