Can i import .Uasset files (UE4 assets) into Houdini? (and if yes, how?)
Snappy_Darko
since I imagine .uasset can store much more than just the geometry, I assume you may need to open them in Unreal and then export parts you need as FBX or something, or pass to Hengine Asset to process and save as whatever
Edited by anim
  • 11 months later...
so it means your saying it's not possible? I think I have watch this somewhere that the author copy a path from unreal engine and paste it inside houdini, I maybe wrong.
  • 1 year later...
This is describing a different workflow. You use "Copy Reference" when you want to do things with Houdini Engine, like setting unreal_material or unreal_instance attribute string values.
To make use of StaticMesh UAsset files in Houdini without the UAsset garbage, right click on the StaticMesh assets in Content Browser, then go to Asset Actions > Export and export as a 3D format like FBX, which you can then import into Houdini.
