davidyannick Posted May 11, 2020 Share Posted May 11, 2020 When I fuse this boolean, extra edges appears, is there a way to delete these edges ? Thanks for your help edges.hiplc Quote Link to comment Share on other sites More sharing options...
Librarian Posted May 11, 2020 Share Posted May 11, 2020 What if? fuse with the power of 2 grid -1.but I use 16.5 sorry, maybe don't work so in H18. edgesFusewithPower2grid.hipnc Quote Link to comment Share on other sites More sharing options...
davidyannick Posted May 11, 2020 Author Share Posted May 11, 2020 thx but I need the grid spacing numbers to determine the number of rows and columns Quote Link to comment Share on other sites More sharing options...
Noobini Posted May 11, 2020 Share Posted May 11, 2020 (edited) well it's the hypotenuse of a triangle, longest of the 3 sides....use trig and select edge group with min length = the hypotenuse length ? something like sqrt(5^2 + 4^2) ? or sqrt(5^2 + 5^2) you sort it out... (or whatever spacing you have in fuse...the hyp has to be greater than the max of the 3 x/y/z spacing) Edited May 11, 2020 by Noobini 1 Quote Link to comment Share on other sites More sharing options...
bobc4d Posted May 11, 2020 Share Posted May 11, 2020 I cleared your rotates on 3rd box and those lines went away. if you need that rotate, then this will give you some direction to go. now as to why, not sure. Quote Link to comment Share on other sites More sharing options...
davidyannick Posted May 12, 2020 Author Share Posted May 12, 2020 thanks to all for your help Quote Link to comment Share on other sites More sharing options...
