scuy Posted June 20, 2020 Share Posted June 20, 2020 I want to split mesh(main.obj) with polypath(cut.obj) . bad result happened. Dose anyone know why this happened? Please find attached file. Thank you. cut.obj main.obj Q2.hipnc Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 20, 2020 Share Posted June 20, 2020 Take Visualise SOp _assign Normals And you gonna see that your spline has Error exact on the same place Quote Link to comment Share on other sites More sharing options...
scuy Posted June 20, 2020 Author Share Posted June 20, 2020 @Librarian What do you mean? Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 20, 2020 Share Posted June 20, 2020 here... Q2_fix.hipnc Quote Link to comment Share on other sites More sharing options...
scuy Posted June 21, 2020 Author Share Posted June 21, 2020 Thank you feed back. resample make sometime good result , but sometime bad result. if set length below , same problem happen. I wanna find versatile solution , because next step I want to apply many polypaths . Quote Link to comment Share on other sites More sharing options...
