Help creating a growing slime mould over a mesh
Sure... assuming you're emitting particles from a source in some given direction, you could project the particles onto the surface using minpos() in a POP Wrangle to find the closest position on a mesh to a given point in space.
Another way to do this is to start with an object that has well-defined UV texture coordinates. You can simply set @P = v@uv in a Point Wrangle (might need to promote the UVs to Point first), solve the simulation, then use Point Deform to warp your finished simulation from the UV-coordinate space back to the original world space.
