Flattening mesh with RaySOP
Fool
Hey Odforce, first time poster here.
I am having a difficult time flattening my polygonal mesh to a flat surface using the ray sop.
My goal is to have a flat mesh having the same shape my mesh had previous to the ray sop, but everything i can handle to create is this "squeezed" mesh as seen on the screenshot.
I tried using the Project geometry node but couldnt get it to work either.
Edited by Fool
You can wrangle this also, should be easier to set up :
vector min_p = detail(0, "P");
//if you want a certain threshold to control the point depending on its y position
//if (@P.y > min_p.y + ch("threshold")) @P.y = min__p.y;
@P.y = min_p.y;
With an attrib promote before the wrangle set up like this :
Cheers,
Edited by DonRomano
syntax
float min_p = detail(0, "P");
@P.y = min_p.y;
Cheers,
This worked out great for me. Thanks! :)
  • 3 weeks later...
@P.y = min_p.y;
Cheers,
No.
You're assigning a point to a float.
Also , promoting a 3 component vector attribute to its minimum doesn't seem like a good idea.
Will it find the minimum value using a lexicographic comparison over R^3, or will it do it independently over each component ? The documentation  is not clear about it
6 hours ago, AntoineSfx said:
No.
Yes, it was a syntax mistake. The minimum find algorithm looks for the minimum for each component, at least with my tests it's what it's doing. He said it was working fine, so I don't understand why you're digging old post to point out a syntax error
