iterate over certain points
amin.khormaei
int pts [ ] = array ( 1, 3, 4 );
foreach ( int pt; pts ) {
      vector _P = {0,1,0}; // Create a vector
      setpointattrib ( 0, "P", pt, _P ); // Here all points would get the same position : _P -> (0,1,0)
{} are missing, and attrib P is a vector, so you must put a vector and not a single integer.
In your case, if you want only change P.y on those points:
      vector _P = point(0, "P", pt); // Get P attribute of point pt
      _P.y = 1.0;
Edited by fsimerey
  On 9/15/2020 at 11:51 AM, amin.khormaei said:
I have this code below:
i[]@TP = neighbours(0,0);
foreach(int i ; @TP)
    @P.y = 1;
how can I tell Houdini to just move the points insideTP array?
foreach move all the points.
Expand
Try this:
    if(i == @ptnum) @P.y = 1;
  On 9/15/2020 at 12:26 PM, amin.khormaei said:
your code doesn't work
Expand
I tried it before posting, it works fine. Can you post what error are you seeing?
      _P.y = 1.0;
Expand
1. {} is not needed in my code. Look here for similar C style syntax rules: http://www.cplusplus.com/forum/beginner/180452
2. You don't need to provide a vector type. VEX will automatically cast 0 into a vector.
    @P.y = 1;
Expand
Expand
In the case of Amin, he seems want to move in Y axis. In your example the 1 give a vector (1,0,0), so moving along X axis AND ALL points are at the same position (1,0,0)...
Good to know for C style syntax ;)
Edited by fsimerey
Expand
No, 1 will become (1,1,1).
I just posted an example. He should be able to adapt it to his needs.
  On 9/15/2020 at 5:08 PM, amin.khormaei said:
thank you for all answers. the simplest way was:
i[]@pts = neighbours(0,0);
foreach(int i ; @pts)
    if(i == @ptnum)
        @P.y = 1;
Expand
if your array is not varying per point (at least from your example) and you still want to use Point wrangle instead of detail you can simplify your code further to
int pts[] = neighbours(0,0);
if(find(pts, @ptnum) >= 0) {
        @P.y = 1;
or @P.y += 1; if you want to offset them instead of hardcode to 1
