UV doesn't stick to Vellum [RESOLVED]
Tijack
Hello,
I'm struggling one more time with the rest position. It's something I really have problem to assimilate.
So I have my vellum hair simulation. Then I applied a wire to create thickness to my rope.
I then applied some UVflatten/layout.
And then the UV doesn't stick to my rope.
I assume I should use rest for that. But it's an eternal misunderstanding between us.
Any help ?
Thanks
Edited by Tijack
6 hours ago, Tijack said:
Hello,
Any help ?
Thanks
place your uv nodes after rest sop node and before attribute copy node. You have to copy uv attribute form rest geometry to simulated.
Edited by vicvvsh
6 hours ago, vicvvsh said:
Indeed !
Thank you :)
I also copy uv attribute from "vertice" to "vertice" (for the next people coming here)
