POP Solver substeps issue...
Masoud
1 hour ago, Masoud said:
Hello;
For some reason I need to increase "substeps" in a "POP solver", but the problem is it increases the number of generated particles!
How can I fix it?
Thanks for helping.
Particle_Substep.hip
Yes, this is how DOP works, each substep all nodes in a dopnetwork cook. As i can see you want particles born just ones, in this case use expression in 'Impulse Activation' parameter:
$ST < ch("../timestep")
It will be independent how much substeps you have.
Hi Victor and thanks for your reply,
I changed the "Impulse Activation"  from $F==1  to  $FF==1 ,  and problem solved.
