Is it possible to use an animated line as an input of a wire-solver input?
Masoud
Hi guys;
I tried to change the length of a curve using Carve SOP over time, and now I want to use it as an input of a WireSolver simulation, but it doesn't work.
How can I fix it?
Or is it possible to use an animated line as an input of a wire-solver input?
Thanks for helping.
WireSolver_01.hip
Hi Tesan;
Thank you for the reply. I checked your HIP file and it's not working as I need.
I want the solver to solve the wires object while its length is changing on each frame, not to change its length after solving...
Regards.
