Zbrush-like details in Houdini
RTHMan
Do you want to creat the patern from a scattering approach or do you want a "height texture bombing" a model with one of these patterns with scattering?
Both are possible anyway, be Houdini is not the right platform to eat billions of polygons as morning pancake, i don't encourage you to push it too much ...
________________________________________________________________
Vincent Thomas   (VFX and Art since 1998)
Senior Env and Lighting  artist & Houdini generalist & Creative Concepts
 http://fr.linkedin.com/in/vincentthomas
That's disappointing. Thanks for the advice.
#define PI          3.1415926535897931
#pragma label       Theta       "Maximum Theta"
#pragma label       spread      "Overall Spread"
#pragma label       DATA        "Data Points"
#pragma label       kd          "Diffuse"
#pragma label       ks          "Specular"
#pragma label       bump        "Bump"
surface
qrotation_field
(   float   Theta   = 2.0,
            spread  = 3,
            kd      = 1,
            ks      = 0.5,
            bump    = 0.1;
    string  DATA    = "$HIP/../VEX/Reading-Data-Points/_datapoints1.bgeo.sc")
    float d, Np, theta, pFratt, factor, pspread;
    vector _P, pP, axis, pVratt;
    vector4 Q;
    string group;
    _P = ptransform("space:camera", "space:world", P);
    theta = snoise(_P + 0.9, 1, 0.75, 1)*4.5;
    axis = snoise(_P + 0.05, 1, 0.05, 1);
    Q = quaternion(theta, axis);
    _P = qrotate(Q, _P);
    for(int g = 0; g < 2; g++){
        group = concat("group", itoa(g));
        int p[] = expandpointgroup(DATA, group);
        Np = len(p);
        factor = g + 1;
        for (int i = 0; i < Np; i++){
            pP = point(DATA, "P", p[i]);
            axis = point(DATA, "N", p[i]);
            pFratt = point(DATA, "fratt", p[i]);
            pVratt = point(DATA, "vratt", p[i]);
            pspread = pFratt*spread/factor;
            d = distance2(pP, _P);
            d = exp(-d*d/pspread);
            theta = 2*PI*(pFratt*2 - 1)*d*Theta/factor;
            _P = qrotate(Q, _P - pP) + pP;
    vector outColor = snoise(_P*0.25, 1, 0.25, 1);
    vector Nn = normalize(computenormal(P + min(outColor)*bump, N, Ng));
    vector diff = diffuse(Nn)*outColor*dot(normalize(-I), N);
    vector spec = specular(Nn, normalize(-I), fit01(min(outColor), 0.5, 0.1))*0.1;
    spec += specular(N, normalize(-I), 0.05);
    Cf = diff*kd + spec*ks;
Make New Asset SHOP_surface and have fun  (you have those files on GITHUB) ...it reads points and attributes that exist on that POINTS ..Just use imaginations ..
Just example ...
Thank you Konstantin, but there are other things I also want.
1. To use curves to influence the formation of the cells.
2. To add textures to the cells and in between the cells.
3. To edit the radius of the cells.
4. To use different alphas for the cells like these images.
60841978402f1_Sharpshape.jpg.36d4b88f209e199f0d19de39eab8995f.jpg60841980432f3_Roundshape.jpg.a314e7fccccba9305aa8a5a34ab6a82a.jpg60841992da677_Softshape.jpg.f258b64cbb153a88ccdf0b87488f6992.jpg
Edited by Bennell
  • Downvote 1
Well, then you have quite a bit of research ahead of you. Maybe this helps:
  1. orient along curve SOP + primuv() can sample tangent directions from curves.
  2. 'texture bombing' adds structures based on image maps
  3. editing the pscale attribute along with pcfind_radius() changes radii
  4. the smooth()-function allows for different roll-offs.
I have published lots of examples here and also some tutorials about this.
  • Like 2
