miccetro Posted June 1, 2021 Share Posted June 1, 2021 Hi guys and girls, I have this condensation on bottle shot I'm working and would love to create a poisson disk distribution with a uniform sample of points based on the area of the triangles in the mesh. I've been looking at the papers written about this but its a liittle bit technical for me at this time. I'm hoping some could maybe look at my file and point me in the right direction to use vex to create this algorithm. Thanks much in advance. poisson_on_bottle_setup.hip Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 1, 2021 Share Posted June 1, 2021 I've never used it but there is a vex func called random_poisson could be useful. Quote Link to comment Share on other sites More sharing options...
Noobini Posted June 1, 2021 Share Posted June 1, 2021 as said, I've never used it so this could be a disaster...just try fiddle around with Mean/Max poisson_on_bottle_setup_mod.hipnc Quote Link to comment Share on other sites More sharing options...
miccetro Posted June 2, 2021 Author Share Posted June 2, 2021 Hi Noobini, thanks for the tip, didn’t know about that function. I’m however looking to create something more like the algorithm in the paper attached! the parts about grouping points by cell ID and the hashtables parts go over my head, but I know with some technical assistance I can implement this algorithm! c95-f95_199-a16-paperfinal-v5.pdf Quote Link to comment Share on other sites More sharing options...
Librarian Posted June 2, 2021 Share Posted June 2, 2021 //detail float r =1; int k = 30; int dim = 2; int width = 200; int height = 100; // fill grid with -1 int grid[]; // -1 is no sample vector grid_pts[]; // -1 is default set(0,0,0) int active[]; // an array of sample indices vector active_pts[]; vector process_pts[]; // cell size of per voxel float w = r / sqrt(dim); int cols = floor(width / w); int rows = floor(height / w); for(int i= 0;i<cols * rows ; i++){ push(grid, -1); push(grid_pts, set(0,0,0)); } printf("cellsize: %d, cols: %d, rows: %d\n",w, cols, rows); // step1 // Select the initial sample,x0, randomly chosen uniformlyfrom the domain float init_x = width / 2.0f; float init_y = height / 2.0f; vector init_pos = set(init_x, init_y, 0 ); // init point from center! int init_i = floor(init_x / w); int init_j = floor(init_y / w); grid_pts[init_i + init_j *cols] = init_pos; grid[ init_i + init_j *cols] = 1; push(active_pts, init_pos); // Insert it into the background grid push(active, 0); // push the first point=0 is active! // --------------------- step2 int sel_active_seed = 1237; int push_active_index = 0; while(len(active)!=0 ){ // choose a random index from it (say i) from active list //printf("length active:%d\n", len(active) ); int rand_index = floor(rand(sel_active_seed) * float(len(active) ) ); //printf("sel rand active index: %d\n", rand_index); vector pos = active_pts[rand_index]; int found = false; //Generate up to k points chosen uniformly from thespherical annulus between radius r and 2r) aroundxi. for(int ns = 0; ns < k; ns++){ float genkseed = rand( (sel_active_seed + ns )*564 ) * 2 * PI; vector genkpos; genkpos.x = sin(genkseed); genkpos.y = cos(genkseed); genkpos.z = 0; float vlen = rand(ns*135 + sel_active_seed *54); vlen = fit(vlen, 0, 1, r, 2*r); genkpos *= vlen; genkpos += pos; // generate our k points //printf("%f %f \n", genkpos.x, genkpos.y); // int col = floor(genkpos.x / w); int row = floor(genkpos.y / w); //printf("col:%d, row:%d\n",col,row); int cond_0 = col >-1 && col < cols; int cond_1 = row >-1 && row < rows; int cond_2 = grid[col + row * cols] == 1; if(cond_0 && cond_1 && !cond_2){ // query neibours int should_insert = 1; for(int i= -1; i<=1; i++ ){ for(int j =-1; j<=1; j++){ int neibour_index = (col+i) + (row+j) * cols; int neibour_grid_data = grid[neibour_index]; vector neibour_pos = grid_pts[neibour_index]; if(neibour_grid_data == 1){ float dist = distance(genkpos, neibour_pos); if(dist < r) should_insert = 0; } } }// end of query near points if(should_insert) { //printf("insert a point\n"); found = 1; // update the grid grid[col + row * cols] = 1; grid_pts[col + row * cols] = genkpos; // update active push(active_pts, genkpos); push_active_index +=1; push(active, push_active_index); push(process_pts, genkpos); break; } } } if(!found){ /* printf("{\n"); for(int i: active){ printf("now active list value: %d\n", i); } printf("}\n"); printf("---now remove id:%d\n", rand_index); if(removevalue(active,rand_index) ){ printf("---after remove active, now has length:%d \n", len(active)); } else{ printf("****remove id:%d faild\n", rand_index); }*/ pop(active, rand_index); pop(active_pts, rand_index); } sel_active_seed += 135; } int i=0; for(vector p: process_pts){ int pt = addpoint(geoself(), p); vector c0 = set(1,0,1); vector c1 = set(0,1,1); float bias = (sin( float(i*0.002) ) + 1.0) / 2.0f; setpointattrib(geoself(), "Cd" , pt , lerp(c0,c1, bias) ); ++i; } to read https://www.jasondavies.com/poisson-disc/ http://devmag.org.za/2009/05/03/poisson-disk-sampling/ Quote Link to comment Share on other sites More sharing options...
Aizatulin Posted June 2, 2021 Share Posted June 2, 2021 You can also use scatter with relax iteration to get quite equidistant sampling. It is a bit slow but you can also use density attribute. poisson_on_bottle_setup_scattering.hipnc Quote Link to comment Share on other sites More sharing options...
vinyvince Posted June 7, 2021 Share Posted June 7, 2021 Not sure i will make it more complicated at it as to myself. Another totally different approach, would be to remesh with high value iteration, place a point at each prim center, compute the area to define the pscale of each point so they will not be colliding. There are multiple desintersect method too off course, Matt from houdini wiki show some for example... ________________________________________________________________ Vincent Thomas (VFX and Art since 1998) Senior Env and Lighting artist & Houdini generalist & Creative Concepts http://fr.linkedin.com/in/vincentthomas Quote Link to comment Share on other sites More sharing options...
