ela1995 Posted August 13, 2021 Share Posted August 13, 2021 I have a DOP Network with multi solver, which spawn rbd sphere with pop solver. How do I make the size of the sphere small at the source, then become bigger as the current size when it touches the ground. pop_rbd.hip Quote Link to comment Share on other sites More sharing options...
GDonkey Posted August 26, 2021 Share Posted August 26, 2021 Hi there, Try putting a Sop Solver between the pop solver and bullet solver. Then in there, a primitive sop, turn on transformations. and use a fit expression with @age to scale them over time starting from when each particle is born. Hope that helps. Quote Link to comment Share on other sites More sharing options...
toadstorm Posted September 5, 2021 Share Posted September 5, 2021 If you want Packed RBDs to grow over time, you need to do two things: scale up the transform intrinsic attribute, and force the solver to recalculate collision geometry. You can do all this in a Geometry Wrangle or POP Wrangle, it's faster than a SOP Solver. matrix3 xf = primintrinsic(0, "transform", @ptnum); scale(xf, 1.02); setprimintrinsic(0, "transform", @ptnum, xf); i@id = -1; // force collision recompute 1 Quote Link to comment Share on other sites More sharing options...
merlino Posted November 23, 2022 Share Posted November 23, 2022 On 9/5/2021 at 6:25 PM, toadstorm said: i@id = -1; // force collision recompute Expand that's the line of the year for me Thanks Henry! Quote Link to comment Share on other sites More sharing options...
toadstorm Posted November 23, 2022 Share Posted November 23, 2022 Note that you don't need to do this anymore as of Houdini 19! You can just set `scale` or `pscale` point attributes during the simulation. They'll scale the transforms relative to the `resttransform` that's automatically generated on the first timestep of the simulation. Quote Link to comment Share on other sites More sharing options...
merlino Posted November 24, 2022 Share Posted November 24, 2022 hmmm ... that's strange, as my setup isn't working without this line, actually using pscale attribute. In order to make it works we had to add this line at the end of the geo wrangle ... maybe is something related to this specific release, 19.0.561, not sure as we can't use newer version for Arnold compatibility, but I'll do a test with a newer 19.0 release on my home pc. Thanks for the advice Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted April 29 Share Posted April 29 On 9/5/2021 at 6:25 PM, toadstorm said: If you want Packed RBDs to grow over time, you need to do two things: scale up the transform intrinsic attribute, and force the solver to recalculate collision geometry. You can do all this in a Geometry Wrangle or POP Wrangle, it's faster than a SOP Solver. matrix3 xf = primintrinsic(0, "transform", @ptnum); scale(xf, 1.02); setprimintrinsic(0, "transform", @ptnum, xf); i@id = -1; // force collision recompute Expand hi i'm really wrestling with this process - i've followed the entagma tutorial that is quite complex. I have some falling pieces that i am trying to shrink down as they fall. I was told i can do this after the simulation process using a primitive node i dont need them to collide as they shrink... just simply shrink over time as they fall (or just after they fall for example) sorry to dredge up an old thread but hoping someone can help? thanks ant shot_MIND_0130_v006_ground.hipFetching info... Quote Link to comment Share on other sites More sharing options...
Sepu Posted April 29 Share Posted April 29 did you have a look at this? 1 Quote Link to comment Share on other sites More sharing options...
anthonymcgrath Posted April 29 Share Posted April 29 On 4/29/2025 at 4:30 PM, Sepu said: did you have a look at this? Expand i did indeed and you solved it with that active_age attribute - thankyou so much Quote Link to comment Share on other sites More sharing options...
toadstorm Posted April 29 Share Posted April 29 I should note that you don't have to modify intrinsics anymore to adjust RBD sims, you can just set template attributes like `pscale` during the simulation and the packed transforms will update to match (relative to the rest transform that's generated on the first frame) 1 Quote Link to comment Share on other sites More sharing options...
