Sign in to follow this
Masoud
RBD fractured objects issue!
Posted (edited)
Hello,
In an RBD simulation, I would like to control the transform/rotation of the elements, to stop them from moving forever. The fractures travel too far away..!
I tried to use the "Drag" node, but it's hard to achieve the right value in its parameters!
So what's the best solution to fix it?
Actually, I want to achieve a falling behavior like what they made in this TVC:
Thanks for helping.
RBD Limiting Drag_02.hip
Edited by Masoud
Share this post
Link to post
Posted (edited)
Try throwing a SOPSolver on the post solve. After the impact frame, scale velocity down.
if(@Frame>18){
    v@v *= 0.1;
Edited by Atom
Share this post
Link to post
Hi Atom,
Thanks for the reply.
I think it does not look natural. I don't want to reduce the velocity of all parts at a time.
The fractures must continue their motion (Transform/Rotation) at a normal speed (after they collide with the ground). Then each part's velocity has to be decreased in a short time based on their mass...
Share this post
Link to post
Hi Tesan,
Thank you for the reply.
You know, I don't want to modify the Glue constraints and "distance" factor. They just control the power of keeping fractures together and so on...
I would like to limit whatever makes them moving/rotating that much.
Share this post
Link to post
Hi Tesan,
The " Interiordetail" is just an SOP (I mean its a post solve operator).
At first, I need to simulate the scene as I explained...
Share this post
Link to post
43 minutes ago, Librarian said:
@Masoud  check this ex from nick regarding sleeping and rest and from sidfx you have some more
https://nicholas-taylor.com/assorted-bullet
https://www.sidefx.com/tutorials/h17-masterclass-rbd-tools-update/
Hi there,
I think, forcing the elements to sleep works fine with the sphere shape pieces, but when you have fractured (rock shape) pieces, they would sleep in a bad position.
Share this post
Link to post
Ok,
I tried to limit the piece's movement, by modifying the "spinresist" and "angaccelmax" attributes in DOP, using a POP Wrangle.
The result is not bad, but I will try to make it much better.
I would appreciate any better ideas ...
RBD Limiting Drag_05.hip
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
