amin.khormaei
As it says in the DOC, we can write an expression inside the stop condition field to stop the loop.
OK, I used a npoints expression and I referred to the end-block node because it's the only node that accumulates the points and prims I think, but I get an infinite recursion error, Please help me.
BEST REGARDS.
Try reaching one node past the end of the loop or before, like sphere1. Use an absolute path. I don't think the foreach_end node can present its final result while calculating it.
Edited by Atom
I did that, the expression successfully change the stop condition from 0 to 1 and vice versa, but the loop didn't stop.
  • 3 weeks later...
  • 1 month later...
