There is a problem with extruding seams lines or applying carves
iasm6419
Thank you @atom.
To help you understand, I am attaching the shape I want to make.
With polyextrude2D it will extrude back and forth, then you need to cut half of the shape. So I don't want it.
I want to make it using seams of edge groups of boolen
ap_Test_J_re.hipnc
Edited by iasm6419
further explanation
PolyExpand2D is not like PolyExtrude, they are different nodes. PolyExpand allows you to "widen" a curve shape, like your Boolean edges. You have options with PolyExpand2D also to determine if the output is 2 separate curves (inside/outside), or a skinned surface. You can use 2 PolyExpand2D nodes to create the extended shape in your example, the first to offset the edge/curve, and the second that generates the surface.
Thanks @Fenolis.
However, PolyExpand2D is not the way I want it to be.
I solved the problem of overlapping faces by controlling the normal, but I was wondering if there is a more concise way.
And I'm curious as to why the faces are flipped when using polyextrude with a carve node.
For me, it's important to know the cause of the problem.
(I know there are many different ways.)
Thanks @Librarian
I looked through the files, but the problem still remains.
I am attaching an additional image because my explanation may have been insufficient.
@iasm6419  <---- P.S. How do you make a yellow “name tag”?
Edited by iasm6419
  • 2 weeks later...
  • 3 weeks later...
