Particles Attracted to separate spheres
terencemace
Hello all,
I'm working on a particle sim where I have a disc of swirling particles, and I want the particles to eventually clump into 5 separate "clumps".
I can do this with one object, using the POP Attract node. However, I'm sure there is a more elegant way to do this with VEX.
Anyone else do this type of effect?
Thanks!
T
I like using pop_steer_seek instead of pop_attract because it has a braking feature when approaching a goal. If you scatter equal number of points on the spheres, you can fetch the position of those points within the simulation and supply them as a goal that the input points will seek.
ap_particles_attracted_separate_spheres.hiplcFetching info...
Edited by Atom
  • Like 2
