is there 'random' for materialX?
pelos
i want to feed some points to a random,  so i get a random  value between 0-1 and feed that to a gradient,  that way with the gradient i can tell what percentage of certain color i want.
but i dont find anything like that.   and if i use the normal random.  the render complains =(
That's a VOP, right? Why wouldn't that work with MaterialX? Just fetch in the result of your VOP which is Cd using the mtlxGeometryColorNode.
You can always pickup a pre-randomzied attribute on the points inside using a mtlxGeometryPropertyValue. Another way is to used one of the mtlxNoise nodes with a signature of float. Read up on them. Some are in the range of 0,1 and others -1,1.
Edited by Atom
i thought when doing materialX  you can only use mx materials   or complains, for example the node "uv cords"  and "mtlx Tex Cords"    or "constant"  and "mtlxConstant"
Edited by pelos
Yes, but you can still read in attributes form your geometry to work with, add noise, etc.   Atom's tip on using the mtlxGeometryPropertyValue is something I use all the time in my MtlxX shaders to pass attributes from the SOP geometry into my shaders for masks, colors, etc.  Just set whatever random value you want on your geometry and then read it into your MtlX shader
thanks, my questions was more about if there a random node in materialX or if anyone had needed to create one before.  (Thanks for the advice on how to bring geo attributes to the shader  =)
if we attach that attribute into geometry adding an additional attribute is adding more disc space when is not needed, will be a lot of geometry.      yes i could add a random value to each prim.    but is smarter to just do it on the shader instead.
  On 7/5/2023 at 7:16 PM, pelos said:
maybe this will provide an idea.
the front row is what i want to get,    but with materialX  i get the back row
Mtlx doesn't have random function yet, you need to set random values on sop level or through noise as mention above, check an example.
materialX_v02.hipFetching info...
that i know how to do, but it adds extra attributes to the geometry. and there will be a lot of geo to save to disk,  and should be done at the shader
we don't want to add another column of attribs
since can be done with normal shaders    should be able to do it with materialX
  On 7/5/2023 at 11:14 PM, pelos said:
magical!!!!   not sure why i was not getting that, maybe i was using the 2d noise and should needed to be 3d?
Fencer you rock!
Probably 2d noise required uv coordinates, value 0 to 1. You have 1,2,3... in incoming attribute.
