Masoud Posted April 12, 2024 Share Posted April 12, 2024 (edited) Hello guys, I want to apply some effects to the "low-density" particles that reach the surface (like bubbles), so how can I select them? Is there any microsolver that helps? I think measuring the SDF can't help because the side walls of the container are close to the particles, too. Thanks for helping. Edited April 12, 2024 by Masoud Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 12, 2024 Share Posted April 12, 2024 @Masoud destination of your effect missing exactly referrer v .... Quote Link to comment Share on other sites More sharing options...
Masoud Posted April 15, 2024 Author Share Posted April 15, 2024 Hi Tesan, I didn't get what you mean Quote Link to comment Share on other sites More sharing options...
paranoidx Posted April 23, 2024 Share Posted April 23, 2024 the fluid has "surface" SDF field, sample from that field to select what you want excluding the bound container Quote Link to comment Share on other sites More sharing options...
Masoud Posted April 25, 2024 Author Share Posted April 25, 2024 Hi Paranoidx, That's the problem: how can I exclude the "bound container"? Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 26, 2024 Share Posted April 26, 2024 @Masoud You want something Like Mask to control That filed or? Quote Link to comment Share on other sites More sharing options...
Masoud Posted April 26, 2024 Author Share Posted April 26, 2024 For say, I need to apply some effects, only to the water's surface, in a cup. So I don't need that effect, where the fluid contacts the container, thus I need an attribute that shows particles on the top of the fluid surface. Quote Link to comment Share on other sites More sharing options...
Librarian Posted April 26, 2024 Share Posted April 26, 2024 @Masoud Yes I get it , air field system and Use in Sop solver inside Your Dop to define yours groups water and Density Mass . You have Files here on Forum or Sidefx forum or Peoples post some strange HDA on web, you can Find if I can . I would make so.. it works in Cup too. Here its just some dir and amp on vel-...If you mean Like This ..a lot to tweeek.. IDK Quote Link to comment Share on other sites More sharing options...
