RBDfracturematerial and UV issue - uvs fine in Houdini.. in maya.. nope.. scene file included
having a bit of a nightmare with this one...  this is my shot... hulk swinging a log at thanos lol (sorry for the 6mb gif!)
so i want the log to explode on impact
so my log geo was created and uv'd in maya... i exported as a cache with the animation as alembic... it all seems to come into Houdini nicely...
I then set it up with rbdmaterialfracture and then some uv nodes to texture the inner pieces..
i just use a simple sphere for collision that i then shrink after impact and move down through the floor to get it out of the way lol!... I have my uv's on the log and it looks fairly nice overall i think... i'm using the rbdconfigure to switch between deforming and active ....thanks to @rohandalvi for his little video tutorial on youtube :)
Here's where it gets tricky in maya... I'm exporting the cache as alembic but its not bringing the uvs in correctly... some parts seem to be nicely textured but then a bunch of chunks aren't working...  this is the log geo in Maya viewport and when rendered it doesn't texture those parts as needed...
Sorry for the longwinded post i just like to use pics to help it be more clear :)
I've included the log abc cache and a the hip file incase anyone wants to take a look and point out where i could be going wrong?
Thanks everyone!
Ant
shot_MIND_0110_log_v01.abc shot_MIND_0110_setup_v001_clean.hip
2 minutes ago, Sepu said:
It is working fine here through Bifrost as you can see. I would just load it through BF since the Alembic implementation is much better than vanilla Maya.
maya_stJRYJN6Xi.thumb.gif.851440ea40cfbc615570c84f3b7aed19.gifmaya_j7Vjdf4YV0.thumb.png.6d9f18f5e215b70c8de8fc31d6fefbf0.pngmaya_fClyZ502Q0.thumb.png.4c0937ad43f48d1269ba50dc724045d6.png
oh wow - tbh i didn't know you could use bifrost to load it up.
So i could just load through bifrost and then assign my log/wood material?
1 hour ago, fencer said:
Nice shot!
Try to split inside and outside geometry, unpack before exporting to alembic.
oh nice - major Duh on my part ...i didn't think of trying that and i've literally done that before now lol! thankyou!
so thanks to everyone who offered advice - so after reading some stuff about importing alembic for bifrost and then for Arnold i thought oooo can i do that for vray?
Turns out you can by using the "import vray proxy" node :)   I just plug the file name in and then added the material and its looking alot better i think overall!
  • Thanks 1
