How to fetch Impact Data within DOPs to dampen velocity
ecstaticrabbit
Hello,
I have a setup with emitting RBD objects, but I would like to reduce their velocity once they hit a collision object. I have the impact data at SOP level but how would I access this data within DOPs? I've attached a hip file with a simplified version of my setup, and I added a wrangle within the bullet solver to demonstrate what I would like.
Thank you in advance.
impactData.hipnc
On 6/29/2024 at 4:13 PM, Sepu said:
Not in front of Houdini at the moment, but you can do this in an SOP solver, you can use the different attributes to damp your velocity.
hey, is it a sop solver within the rbd bullet solver? I've tried this but it doesn't seem to read in the impact data attributes for some reason.
  • 2 weeks later...
