Masoud Posted Tuesday at 04:49 PM Share Posted Tuesday at 04:49 PM Hi everyone, I'm trying to copy some grass onto the top of my Vellum grains simulation. However, the grass blades aren't aligning with the direction of the grains — they always point straight up instead of following the grains' orientation. Does anyone know how I can make the grass follow the grains' axis properly? Thanks in advance for your help! Grain Grass_01.hip Quote Link to comment Share on other sites More sharing options...
Librarian Posted Tuesday at 10:31 PM Share Posted Tuesday at 10:31 PM Check rolling debris file in qLib Master files (workFlow) . You need orient Att.. @Masoud Quote Link to comment Share on other sites More sharing options...
Masoud Posted Tuesday at 11:33 PM Author Share Posted Tuesday at 11:33 PM Hi Tesan, I've downloaded and installed qLib, but I haven’t been able to find any clear documentation or guidance on how to use it. Is there a simpler way to achieve this effect, or could you point me toward any resources that might help? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Librarian Posted Wednesday at 06:52 AM Share Posted Wednesday at 06:52 AM I just used last vex after simulation that you have in That file . For more advance Trick and Study if you search Grains orientation you gonna find some Studies on that Topic and Vex Codes. @Masoud Quote Link to comment Share on other sites More sharing options...
Masoud Posted Wednesday at 11:32 AM Author Share Posted Wednesday at 11:32 AM (edited) I opened the "rolling_debris.hip" file and confirmed that the POP Solver already aligns particle orientation to the surface correctly, without requiring any additional code. What I actually need is the same behavior for Vellum Grains, but it seems that Vellum doesn't orient the particles properly by default. I searched for "Grains Orientation" but couldn’t find any helpful tips. Since the Vellum solver doesn’t compute orientation by default, I manually applied an initial orient attribute before the solver. This stabilized the orientation, but now I need it to align properly with the animation. Edited Wednesday at 11:32 AM by Masoud Quote Link to comment Share on other sites More sharing options...
Masoud Posted Wednesday at 12:17 PM Author Share Posted Wednesday at 12:17 PM I added the "up" and "orient" attributes before sim, and included these lines of code after it. The alignment has a little improved, but it's still not exactly what I need: vector axis = v@v * v@up; float angle = @Time * $PI; vector4 spin = quaternion(angle, axis); @orient = qmultiply(@orient, spin); The issue is that the grain's orientation resets to its initial state after they reach to the rest (zero velocity). Any ideas to improve it? Quote Link to comment Share on other sites More sharing options...
Masoud Posted Wednesday at 12:18 PM Author Share Posted Wednesday at 12:18 PM (edited) @Librarian Could you share the codes, please? Edited Wednesday at 07:08 PM by Masoud Quote Link to comment Share on other sites More sharing options...
Librarian Posted Thursday at 06:47 AM Share Posted Thursday at 06:47 AM I just copied All from that file(rolling_debris )@Masoud without to take consider all attributes that have no Impact on your Setup. Just search "Grains Rotation" , you have some Vex solution and some Heavy Study on That Topic. Quote Link to comment Share on other sites More sharing options...
Masoud Posted Thursday at 03:55 PM Author Share Posted Thursday at 03:55 PM Here’s my scene using the same network, but it doesn’t work: Grain Grass_10.hip Quote Link to comment Share on other sites More sharing options...
