papicrunch
IES light shape
Hello,
I want to know if there is a way to import IES file into houdini' lights ?
thank,
papi
sorry for my english
Share this post
Link to post
Hello,
thank,
papi
AFAIK there is no ready to use tool for that. After all if you're not interested with recreating any particular light but rather having similar control on ligth cone, you can do it without IES...
igs.hip
Share this post
Link to post
nice example Symek!
i would still like to see IES light profiles in Houdini, especially since we have Physically based rendering
jason
Share this post
Link to post
thank for reply,
But in your exemple the shape of light is only in "2D"' projection, with IES the patern's light look much "3d"
Here just un simple exemple in maya :
papi
Share this post
Link to post
I guess this would require a real IES parser in the light shader.
A workaround would be to roll your own light shader that reads lookup tables for light Intensity in 3D
Acording to this source [1] the last three sets of numbers in an IES file define vertical and horizontal angle values and the candela value at this point.
Once you convert these to ramps the light shader could calculate the bearing of the sample and look up the intensity of the lamp in this direction.
[1] http://www.vuw.ac.nz/architecture-onlinete...ard_format.html
Share this post
Link to post
thank for reply,
papi
Well, you are right, this is not fully functional IES light setup, but 2 minute example. It doesn't bother with light distance / attenuation. I used to deal with that issue but failed miserably by IES file parser (which is crude format, but exists in a few flavors). As Georg says, adding distance attenuation per ies sample would require writing your own light shader (nothing that can't be done in a week or so).
Edited by SYmek
Share this post
Link to post
ok thank for advice,
I really new in houdini world but I will take look, how capture informations in IES file and try to use them into light or 3d texture.
papi,
sorry again for my poor english speak :(
Share this post
Link to post
papi,
Maybe you can convince rdg or SYmek to anamous to try to make an IES shader for you:)
Share this post
Link to post
Sounds like a shader a day :)
Share this post
Link to post
Let it be Sunday, Georg :ph34r:
Share this post
Link to post
One of the rare examples where the op:// reference doesn't work so well. It brings my 3d viewport interaction to a crawl.
Share this post
Link to post
Hmmm... not so trivial, this.
Writing the shader to output different intensities based on axial angle, sure, five minutes. Encoding a distribution in a way that can be used to parameterize the shader? sure, ramps will do for axially symmetrical distributions, but for quadrant and plane symmetries, as well as for fully volumetric distributions... well... you need to get a little more creative (array of ramps + filtered lookup function?).
Finally, assuming you have a nice compact representation for all distribution types, which the light object can store locally and use to parameterize the shader, then, if you want to be able to load arbitrary definitions from file in standard ies format (which is the whole idea, right?), you need to deal with the whole parsing issue... not a biggie, but it's there.
So yeah, the shader itself is definitely a "shader-a-day" thing :)
But for a full-featured, flexible IES light object (to drive this simple shader)... a few days, I would think.
Share this post
Link to post
Another potential gotcha:
I've found, too, that using the op:/ syntax to reference floating point images can screw up in the IFD on the way to Mantra. Setting your comp to 8-bit solves this. Admittedly this was a few months ago that I tried this.
Perhaps a different bit depth might affect your viewport speed too?
Share this post
Link to post
Aware of this and appreciate your thoughts, I am. Yes, hmmm.
Two ramps won't suffice but a nice image will do.
A full blown IES will probably not be the result of this exercise, but maybe a IEStoLightMap.py.
Unlikely, taking my C/HDK ignorance into account.
op:// textures aren't anti-aliased I was told from the first day.
Share this post
Link to post
Yup, an environment map might be a good choice to support everything, including volumetric distributions.
Share this post
Link to post
:unsure:
the environment map might also be a shortcut to the azimuth/roll/hither calculation ...
:unsure:
As the acos(dot(normalize(L), vector3(0, 0, 1)) to create a 0..360 degree angle worked fine in SOPs but somehow gets screwed up in the light shader.
This snippet doesn't give a 0..360 of course, I test if L.y - respective L.x - is < 0 and add 180 if so ...
Edited by rdg
Share this post
Link to post
Not sure what you're after exactly, but if you're looking for the axial angle, the I'd imagine that inside the light context, it would look something like acos(dot(normalize(-L),normalize(Lz))), which has a range of [0,PI]. (but I'm going by memory here... I *think* Lz is in current space but you should double check that).
Share this post
Link to post
Not sure what you're after exactly, but if you're looking for the axial angle ...
Oh wait. You're probably looking for a way to get the lat-long angles, right? (elevation and azimuth)
If that's the case, then just get L in the light's space (unit length) and derive the angles from its components. Something like this:
vector v = normalize(vtransform("space:object",-L));
float latitude = acos(v.z); // range [0,PI], measured from the light's z-axis
float longitude = atan2(v.y,v.x); // range [-PI,PI], measured from the light's x-axis
Share this post
Link to post
Didn't know how lost I was
Until I found you.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
