Silly Challenge
David Gary
So... You asked for challenges... :lol:
For procedural minds ,
If and only if you have time!
1)Break a piece of geometry in shards ( each shard is not a single primitive but a group of primitives , which is much mooore difficult to achieve)
2)Animate the shards with a particle network ( so it's not just instancing...).
sorry i didn't post a more complex animation, but ut's just to show the concept
3)Plus ( that's what i did) : the division of the piece must be procedural ( to have control over crack patterns, that is you must define procedurally the groups of primitives).
EVERYTHING MUST BE PROCEDURAL :)
sorry for the adGif logo. I do not create animated GIFs very often!
Okay Mr FrenchOP, Please disclose brain power. The ice breaking tutorial is easy enough but for the life of me I can't figure out how to group the primitives, but then I'm fairly new to Houdini. I'm sure I'll kick myself when I find out.
Thanks
  • 1 month later...
I'd appreciate a hint concerning the following: can a single group SOP output multiple groups or a fuse SOP do multiple seperate fusions ?!
Defining the pattern for the actual groups seems easy enough for me, and I think I know how I could create a script that simply creates a seperate fuse or group SOP for each fragment, but having all these seperate fuse / group OP's doesn't sound like an elegant solution to me / has little procedural beauty ;).
  • 2 weeks later...
Yo guys! Did any of you crack this challenge? I am working on my master's project at the moment - basing much of my particle stuff on the ice breaker (with basher object) - and I would really like to be able to group the primitives into different sized chunks.
Question: wouldn't it be possible to create a lumamap in COPs (some kind of shattermap) and using the pic()-function, grouping and fusing primitives based on this information?
ANY input on this is extremely welcome!
:D
Cheers, jostein.
I tried working on this last night for about 4 hours and didn't get anywhere. <_< I tried using the facet to make everything unique and then group primitives to form the shapes I want. Problem is I could figure out how to fuse the primitives together to be one big chunck instead of 5 individual ones. But this gives you no easy way to control the crack patterns anyways so back to the drawing board. :o
  • 2 weeks later...
I wasn't really happy with my solution and I'm going to do a hopefully nice/cleaner setup, but anyhow ...:
I created an extra attribute on the points of the grid and using a VEX SOP I simply applied a slightly modified voronoi kinda noise on this attribute: the voronoi noise has a bit of this cobblestone look. So far so good... now I used the Partition SOP to create the unique groups based on this . I don't know anymore if I created primitive or point groups, but I used something similar to the following roule: "point ("/obj/Ice/IceBr", $PT, "myCustomAttribute", 0)"
Using the trick Sebarrik suggest in his "prim sort otl" I did a loop, through all the groups and animated these that way. Unfortunally my noise would generate numbers ranging from as low as 00001 up to 99999 (--> ugly group names) no matter if I'd have only 7 groups created via the partition using these values or 1000.
Looping though all those non-existant groups was very inefficient and therefore I created an intermediate attribute and tried several simple hash functions to create somewhat unique numbers ranging only from 0 - 4 * times the number of unique groups the partition SOP would create. Trouble is, for proper hashing you usually need some collision resolving and I don't know how to do so using the expression language in Houdini. Anyhow anyone who's intrested in the hashing theory can get a good introduction on this subject in the good old "Introduction To Algorithms" by Cormen.
In the end using this "hashed" groups some of the initial groups got fused and therefore a fair bit of trial and error was required when playing with the hasing functions.
Well, I guess FrenchOP has a nicer solution for this ;) If I find my old scene file I'll post it.
Jens
  • 4 weeks later...
  • 3 months later...
I'M BACK I'M BACK I'M BACK I'M BACK I'M BACK I'M BACK
Hi Guys!
I had no Internet connection since June 2004 !!!! ( long holiday at remote places with no Internet ( or just mail ) and many problems to get my connection back with f..ing french providers - Not working in an office.. )
Now, I have it back!
I'm gonna explain everything. And more!
( I will do a Three-Parts Video Tutorial with general concepts for doing this kind of FX and some others like
- creating a fluid flow through a L-system ( for lava flow - blood flow)
- "peeling" a surface with arbitrary peels ( often needs math).
Just give me time! ( and luck with Internet! )
Hi guys!
I spent my Sunday afternoon struggling with my computer to do a correct ( and even good sometimes) video tutorial for the Breaking Objects effect ( no error allowed while recording myself in realtime).
Sorry for my -sometimes- ugly akzent.
The other tutorials are coming soon ( the Avalon Fx is almost done)
The main concept of this three or four-part tutorial is copying operations, that is instancing an operation ( or several ) applied to pre-defined parts of an object.
Click here to watch the tut! ( sorry it weigh so much! )
