Isosurface Spiral Function
karipu
I just discovered the Isosurface SOP, and I am especialy interrested in the "Implicit Function", easy and light way to make volumes. I looked around on the internet for different equations to add in that parameter and found some, like this one to make a torus :
(1-.15*($X^2+$Y^2+$Z^2)^2) -(1-($X^2 + $Z^2))*10
But I still can't find the equation of a 3d spiral like they do with POV-ray. Maybe some of you know other function equations to use for the Isosurface, and especialy to use as spiral?
This took me a bit of working out but the following should give you a helicoid:
$X*tan($Z/ch("c"))-$Y
with "c" being an extra parameter. "c" is very sensitive to changes so I haven't been able to make a beautiful spiral yet but a value of 0.002 should get you started.
Thanx Macha for your equation. I used it with a sin and cos function, and it works pretty well :
$X*cos($Y*ch("c"))+ $Z*sin($Y*ch("c"))
We could even get an helix like a screw, combining this with a tube (with "r" as the tube radius, and "R" as the helix radius, or something like that):
($X*cos($Y*ch("c"))+ $Z*sin($Y*ch("c"))) * ch("r") - ($X^2 + $Z^2)-ch("R")
But still, it is not exactly the spiral shape i was looking for, and I still can't find it (see attached picture)
Sorry, I'm getting a bit carried away with this, :D , but I noticed that we can add and position new objects within the expression.
Whereas the previous one was copy-stamped this one isn't. Once we have an object we can add a new one by multuplying it, and position it by offsetting the x,y,z, and scaling it by adding a float. Like so:
((2*($X+.5)^4 + 2*$Y^4 + 2*$Z^4 - 0.2)*
(2*($X-.5)^4 + 2*$Y^4 + 2*$Z^4 - 0.2))*
(2*(0.5-$X)^4 + 2*(1.1+$Y)^4 + 2*$Z^4 - 0.2)*
(2*(0.5-$X)^4 + 2*($Y)^4 + 2*(1+$Z)^4 - 0.2)*
(2*(0.6-$X)^6 + 2*(1.2+$Y)^6 + 2*(1.1+$Z)^6 - 0.02)*
(2*(0.5+$X)^4 + 2*(1.1+$Y)^4 + 2*($Z)^4 - 0.2)*
(2*(0.5+$X)^4 + 2*(1.1+$Y)^4 + 2*(1+$Z)^4 - 0.2)*
(2*(0.5+$X)^2 + 2*($Y)^2 + 2*(1+$Z)^2 - 0.5)*
(2*(0.35-$X)^2 + 2*(1-$Y)^2 + 2*(0.7+$Z)^2 - 0.5)
It is conceivable that we could write a script that automates such things.
Completely useless of course.
It seems that the net is pretty much devoid of spirals like this. The reason, I believe, is that most of the equations generating such surfaces are algebraic equations, meaning they can only contain polynomials with integer exponents. So, functions like sin and cos are in the strict sense not allowed. However, that does not mean spirals are impossible. If you can use functions other than those made of polynomials (and Houdini can) then it is possible. It's just that there's not much of it around on the net.
On the other hand, you can make a series expansion to the desired degree of precision. So, like this:
($X*(1-(1.5*$Z)^2/2+(1.5*$Z)^4/24-(1.5*$Z)^6/720+(1.5*$Z)^8/40320-(1.5*$Z)^10/3628800)+$Y*((1.5*$Z)-(1.5*$Z)^3/6+(1.5*$Z)^5/120-(1.5*$Z)^7/5040+(1.5*$Z)^9/362880-(1.5*$Z)^11/39916800))^2*($X^2+$Y^2-1)*($X^2+$Y^2-6)+16
Edited by Macha
This one generates a spiral. However, the crossections don't sweep properly with the curve (always parallel to one axis) (Apparently this is a hard mathematical problem to solve)
pow($X-ch("r2")*sin(ch("o")*$Z),ch("n")) +
pow($Y-ch("r2")*cos(ch("o")*$Z),ch("n"))-
pow(ch("r1"),ch("n"))
with n=2, r1= 0.2, r2 = 0.4
And here some pointless implicit isosurface equation madness!
It consists of a helix, a sheared and twisted torus, and some other undefined stuff, as well as scaling, moving,union and intersect of those objects.
min(min( (( ($X+ch("xoff"))^2 + (($X+ch("xoff")) + ((($Y-ch("zoff"))^2 + ($Z-ch("zoff"))^2)^0.5) * ch("s"))^2 + ($Z-ch("zoff"))^2 + (ch("r2")^2)-ch("r1")^2)^2 -
(4*ch("r2")^2)*(($X+ch("xoff"))^2+(($X+ch("xoff")) + ((($Y-ch("zoff"))^2 + ($Z-ch("zoff"))^2)^0.5) * ch("s"))^2)),pow(($X)-ch("r2")*sin(ch("o")*$Z),ch("n")) + pow($Y-ch("r2")*cos(ch("o")*$Z),ch("n"))-pow(ch("r1"),ch("n")) ),
(max(2- (cos(($X*ch("mx")) + ch("t")*($Y*ch("my"))) + cos(($X*ch("mx")) - ch("t")*($Y*ch("my"))) + cos(($Y*ch("my")) + ch("t")*($Z*ch("mz"))) + cos(($Y*ch("my")) - ch("t")*($Z*ch("mz"))) + cos(($Z*ch("mz")) - ch("t")*($X*ch("mx"))) + cos(($Z*ch("mz")) + ch("t")*($X*ch("mx")))),($X*ch("mx"))^2+($Y*ch("my"))^2+($Z*ch("mz"))^2-2)))
I don't know about you, but I don't see why one would want to use the Isosurface SOP to create spiral. If you want a volume, then just convert a regular spiral curve into one. From this page ( http://klatte.tripod.com/pov/helix.html ), it's not even using an implicit surface in POV-Ray.
When I try to plug this into the isosurface node I get an error "bad parameter reference "ff"" and same thing for parameter "bb"
What is causing that?
Thanks
Alex
Some of the expressions have extra parameters. You can either replace them by a float or you can go to the little gear icon and create your own parameters (called ff, and bb, etc). That way you can change values inside the expression by just using a slider.
