Houdini 6.1 Apprentice Available
Wolfwood
  • Replies 45
  • Created
  • Last Reply
Top Posters In This Topic
hey! me too :)
I just got off the bus from Toronto :)
it's a neat little package...
inside are pictures of:
"Xyne Fusion Commando" by Nate Nestler
"507" by Matthew Clubb
"Centaur" by David Rinder
"Sky Palace" by david Cao
and in the "Quick Reference Card" has MCronin's monkey guy :)
ummm...no IRIX or Solaris install though...strange
an the docs are still old....
well time to install this bad boy... :)
yep, the one at Vislab is newer than the build on the Apprentice 6.1 EA CD...
here's some more info about What's New in 6.1 :
New Features in Houdini 6.1 - So far....
Interface
Ability to select multiple nodes and simultaneously change common parameter values in the Parameter pane.
Brush support for pressure sensitive tablets
Brush support for smart painting of non-connected meshes
Option to color transform axis handles as RGB (Main Preferences > Handles)
Overhaul of the presets mechanism for fast, easy access to parameter presets
Mouse wheel support under Linux
Network autopanning when a tile is dragged outside the worksheet bounds
Auto-save feature
Digital Assets
Ability to easily promote handle bindings and parameters to type properties panel.
Better naming of channels when dragged to type properties panel
Ability to filter parameters that will be promoted when using drag and drop
Tree-browser interface for dragging special parameters such as toggles or menus
Ability to create nested folders in digital asset Controls panel
Ability to select a digital asset within a digital asset and see appropriate handles
Characters
Muscle deformer (Inflate tool) that works with arbitrarily shaped musculature
Simpler and more intuitive Pose tool that works well with digital asset characters
Flipbook feature for fast play-blasting OpenGL-rendered animations
Attribute Transfer tool to copy attributes from one model to another by proximity
Inverse kinematics enhancements for squash-and-stretch of bone chains
New pick-walking capabilities for bones and objects (page up/page down)
Ability to reposition joints after locking the captured geometry
Texturing
Ability to create VOP networks within other network types
Easy visualization and selection of flipped polygons in UV viewport
Rendering
Improved RIB generation of photon maps
Compositing
Significant stability and performance improvements
Other
Many enhancements to the L-systems grammar and rule set
Many new embedded expressions
yeah...it's really cool...the parameters pane has a little note in yellow that tells you how many nodes you have selected...it works just like it should, at least just as Maya does when you select multiple objects...
hmmm..."common parameter values" could mean that it would work on all kinds of stuff - so long as they are common to the nodes selected...hmm...better than Maya...
Yip, that's exactly what it means.
Actually its even more powerful than it lets on. For instance, lets say you select a buncha objects and want to change their translation parameters. If you type in a value for each one (say you put 50 into tx), then it will override all the selected tx's to 50.
But if you middle click and drag using the ladder slider, then it will update all the tx's relative to whats in them already.
Brilliant I say.....
Marc
I've always thought it would be cool to copy nodes in a network then paste into a text file and get the opscript version of the network....Shake does this and it's way up there on the 'cool meter'
Actually this is exactly how Houdini does it. Although I'm not sure where the "text" file is stored at.
Check out the $TMP/*.cpio files.
jim.
OK, this doesn't have anything to do with new stuff in 6.1, but I just noticed that you can copy an op network from one houdini session, and paste it into another!
Pretty damn cool. :ph34r:
Hey DaJuice,
You can do that in Houdini for the longest time. It's one of the most convenient (life saving in some cases) feature ever!!! :D
Cheers!
steven
Interface
Wasn't that feature there already since Houdini 6.0.x? :huh:
What's bizarre is that once you copy some nodes, you can quit Houdini entirely, reload it and still be able to paste.
On Irix, /tmp is cleared out when you reboot though thus losing what you copied. On Windows, no such thing happens and you can paste your copied nodes even after you turn off your computer and boot it up the next day.
  • 2 weeks later...
