concept4 Posted August 17, 2003 Share Posted August 17, 2003 Hey all. I started this yesterday night. Tell me what you think. I used i3d and I could only do 128 cubic resolution on the 3d textures. I hope I can do 196 or higher with my linux boxes. I got a nice yelling face model from a friend. Gonna try to put it in the sand wall like the mummy. tips and comments! Thanks --Ronnie -------------------- Progress so far: >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> http://megaplex.hypermart.net/houdini/dese..._video_high.wmv <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<< Quote Link to comment Share on other sites More sharing options...
concept4 Posted August 17, 2003 Author Share Posted August 17, 2003 I rendered this on my linux box at 256 cubed res. Looks much better I'll definately be doing it at least with this res. --Ronnie Quote Link to comment Share on other sites More sharing options...
slorender Posted August 19, 2003 Share Posted August 19, 2003 it's looking real good. the actual cloud looks great. a suggestion of mine would be to make sure the sand "cloud" blends more with the actual sand dune. it looks like a sudden change between cloud and solid. b.t.w. - how long is it taking to generate your i3d textures at that resolution??? keep rockin' Quote Link to comment Share on other sites More sharing options...
anakin78z Posted August 19, 2003 Share Posted August 19, 2003 Looks great! I agree that a lot more work needs to be put into the 'connecton' between sand and wall. Keep us updated Quote Link to comment Share on other sites More sharing options...
concept4 Posted August 19, 2003 Author Share Posted August 19, 2003 Thanks for the comments. The i3d texture takes about 3-4 min at 128. 256 it takes about 15-20 min. I've started to do 300 frames of the sand cloud this morning. Hope it looks good at the end. I agree with the blending issue. I'm pretty sure I can do some nice tricks in compositing for it since it's only visible to that extent when the cloud rolls down the hill. When its on the ground and going at the camera the edge is covered quite well with the bumps in the sand. When it's traveling along the ground the particles start moving back and they come over like a wave and then back over so it's like the sand is being pulled off the ground. I've got to add a lot of detail to the ground like sand layer that's blowing over the surface and make a good shader for it. That's a default dent in the vex builder without any special ops. I've got till next week to finish this and the i3d textures are gonna kill my machines for a couple days. --Ronnie Quote Link to comment Share on other sites More sharing options...
slorender Posted August 19, 2003 Share Posted August 19, 2003 fixin' in the comp is the way to go. i figured that is what you would do. very cool, make sure to post a QT when you are done, so we all can check it out. Quote Link to comment Share on other sites More sharing options...
concept4 Posted August 19, 2003 Author Share Posted August 19, 2003 putting up a QT here is for sure! It'll be my first work in houdini. First time using it was in the hotel during siggraph right after the sidefx meeting. Quote Link to comment Share on other sites More sharing options...
rebo Posted August 21, 2003 Share Posted August 21, 2003 How much disk space are your i3d files taking at 256^3 Quote Link to comment Share on other sites More sharing options...
concept4 Posted August 21, 2003 Author Share Posted August 21, 2003 How much disk space are your i3d files taking at 256^3 Well, my biggest so far is 26.5 mb and my smallest is 14.7 mb. I've got a good 68 frames left. 300 total. --Ronnie Quote Link to comment Share on other sites More sharing options...
concept4 Posted August 26, 2003 Author Share Posted August 26, 2003 Hope you like it I worked on the blending as much as I could but I had to finish it early for my project. I still have a face I'm going to put in the sand. If you guys at odforce can host the good quality larger res version that'd be real nice I'm gonna render out the breakdown shots and put it all together nicely. It's in windows media format. (sorry I know) I'm buying a hosting service in a couple days so this < 1mb file will have to do. >>>>>>>>>> I posted a higher res version further down the thread <<<<<<<<<<< Quote Link to comment Share on other sites More sharing options...
rebo Posted August 26, 2003 Share Posted August 26, 2003 I think its a really great effect well done. Quote Link to comment Share on other sites More sharing options...
jjstanley Posted August 27, 2003 Share Posted August 27, 2003 Very cool! A very good job in my opinion. The only thing that didn't look quite right to my was that the surging motion looked a bit to uniform. I think if the front of the dust was a bit less consistent it might seem more real. Just an idea. Keep up the good work! Jerry Quote Link to comment Share on other sites More sharing options...
renderfox Posted August 29, 2003 Share Posted August 29, 2003 Superb! Nice work! In my opinion you could add some add-ons (visial), like dust clouds which go away from main storm... Quote Link to comment Share on other sites More sharing options...
Stremik Posted August 29, 2003 Share Posted August 29, 2003 If you don't mind my saying... the motion of a sand wall looks kinda like it's alive. Reminds me of a running man(don't mistake for A. Shwartzeneger ) I guess it's ok if you were going for something like in "The Mummy" and if not, than it should look more natural. Like an avalange. Anyhoo. Two thumbs up! Quote Link to comment Share on other sites More sharing options...
concept4 Posted August 29, 2003 Author Share Posted August 29, 2003 Thanks for the comments. I'm trying to do it mummy like. I have a face I'm still putting inside it. --Ronnie Quote Link to comment Share on other sites More sharing options...
concept4 Posted August 29, 2003 Author Share Posted August 29, 2003 Here's a better resolution of it. http://megaplex.hypermart.net/houdini/dese..._video_high.wmv Quote Link to comment Share on other sites More sharing options...
cs00bren Posted August 29, 2003 Share Posted August 29, 2003 I like the Vid have any idea what your going to use it for! bren Quote Link to comment Share on other sites More sharing options...
concept4 Posted August 29, 2003 Author Share Posted August 29, 2003 nothing at all. lol. It was mainly to move my skills over from maya to houdini. --Ronnie Quote Link to comment Share on other sites More sharing options...
Shannon Posted September 21, 2003 Share Posted September 21, 2003 Looks great. Are you using Jason's method for voxelizing geometry or is that all particles and copied metaballs? Or some other method? Also, I wasn't aware of a limit on i3d resolution using a windows box. Is this in general, or specific to your win box. Or just a speed issue. Quote Link to comment Share on other sites More sharing options...
concept4 Posted September 22, 2003 Author Share Posted September 22, 2003 Thanks They are all particles. The metaballs are created by the i3d ops and rendered with the meta cloud. The limit on my windows box was cause of my systems resources. Not a limit on the OS, I found linux to be much quicker and more efficient when generating the i3d files. --Ronnie Quote Link to comment Share on other sites More sharing options...
