martin's sketchbook
sanostol
Hi, I just want to have a thread for quick stuff, I'm experimenting with.
maybe this one helps some to save time. emitting from moving objects often end with high subsampling or You can see the emission steps.
by interpolating teh current and the previousframe, You can avoid this efficiently.
fakesubframes.mov
fakesubframes.hip
Edited by sanostol
smoke driven by the particles, a lot of smoke doesn't get around the corner
pretty cool curve tool, i would suggest throwing in a gradient of a tube extruded along the curve into your velocity field to keep the smoke in bounds
@kumpa: in all cases subframes are set to one, for the first example it woudl need 16+ subsamples to get that even distribution
i have been a bit moronic, all clear now. Clever trick, thanks for sharing.
Edited by kumpa
@kumpa: hope it saves You some time :)
@Ryan: glad You like it
I ported the POP setup to DOP as a SOPSolver, just to for fun and by this it is possible to query the pointcloud itself, what is not possible in POP context (This is not include in the file)
movealongcurveDOP.hip
Edited by sanostol
  • 1 month later...
  • 1 month later...
  • 3 months later...
  • 4 months later...
