cytrox Posted September 27, 2003 Share Posted September 27, 2003 Hi, I've done a (quick and dirty) VEX mode for emacs, with syntax highlighting and the ability to compile directly out of emacs (including the ability to jump directly to source code lines where errors occured). As I said, it's a quick hack (originally based on the renderman shader mode by Steve May, but most parts had to be rewritten) and I'm by no means an elisp expert, but it works, so if anybody is interested, here it is Cheers Jens P.S. If anybody is also interested in a renderman shader mode with the same features, let me know and I will post it too. vfl_mode.zipFetching info... Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted September 27, 2003 Share Posted September 27, 2003 *yoink* Thanks. Now how about a hscript one. jim. Quote Link to comment Share on other sites More sharing options...
edward Posted September 27, 2003 Share Posted September 27, 2003 Does anyone use emacs with the Alt-e key? Quote Link to comment Share on other sites More sharing options...
cytrox Posted September 27, 2003 Author Share Posted September 27, 2003 I have jed set as $EDITOR. same keybindings as emacs (well, at least the basic ones). I like jed for editing small stuff, like config files etc., where emacs would be overkill. As for a hscript mode, why not And here an update of the vex mode: Changes include the ability to set the vcc command line from within emacs (via M-x vfl-set-vcc-cmd), the ability to render directly to an otl (via C-c C) in the moment hardcoded to "vcc -l filename.otl filename.vfl", and the ability to render a test image directly out of emacs: you have to have a running houdini instance, open a port via "openport 5000" in the textport (port number hardcoded for now), setup a scene and a output mantra driver, install the otl containing the shader and apply it to some geometry, and then you can render directly out of emacs with C-c C-r, change the shader sourcecode, compile and rerender, all without leaving emacs. The way it works is quite crude, and I would be happy about suggestions for improvement.. For now, emacs just calls "hcommand 5000 \"mwrite $HIP/$HIPNAME; opcd /out; render mantra1\"" The mwrite part was the best I could come up with to make houdini update the otl which changed on disk, by simply saving teh current hip file, as there is no "reload otl definition" hscript command I am aware of.. I think I will make most hardcoded parts (port number, rop name etc.) user-configurable in the future, and I'm very interested in any suggestions for making the whole workflow better and more streamlined. What is your general workflow when writing vex shaders and ops? Cheers Jens vfl_mode.zipFetching info... Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted September 27, 2003 Share Posted September 27, 2003 edward said: Does anyone use emacs with the Alt-e key? I do. Partly because I like emacs more than vi and partly because it annoys the hell out of ken. jim. Quote Link to comment Share on other sites More sharing options...
concept4 Posted September 27, 2003 Share Posted September 27, 2003 Emacs! Noooooo! vi > * --Ronnie Quote Link to comment Share on other sites More sharing options...
Jason Posted September 28, 2003 Share Posted September 28, 2003 i'm a nedit man. nedit nedit nedit. ps. anakinz78 made a nedit vex language syntax highight thing. wanna share? Quote Link to comment Share on other sites More sharing options...
edward Posted September 28, 2003 Share Posted September 28, 2003 ok, try VISUAL instead of EDITOR. Might eliminate that extra shell window. Quote Link to comment Share on other sites More sharing options...
concept4 Posted September 28, 2003 Share Posted September 28, 2003 You know, i'm curious. I'd love to see a poll on here on the different editors. --Ronnie Quote Link to comment Share on other sites More sharing options...
Marc Posted September 28, 2003 Share Posted September 28, 2003 concept4 said: You know, i'm curious. I'd love to see a poll on here on the different editors. I think filthy.... er.... geriatric.... er... horribl.... er.... I think vi would win. Marc P.S. hohoho... Quote Link to comment Share on other sites More sharing options...
stevenong Posted September 28, 2003 Share Posted September 28, 2003 Jason said: i'm a nedit man.nedit nedit nedit. ps. anakinz78 made a nedit vex language syntax highight thing. wanna share? Hey Jason, Nedit's C++ syntax highlighting will work for VEX too. Go to Preferences -> Default Settings -> Language Modes... In the dialog, select C++ & add .vfl into the File extensions parameter. Personally, I also add .cmd & .ds into the list. Cheers! steven Quote Link to comment Share on other sites More sharing options...
Jason Posted September 28, 2003 Share Posted September 28, 2003 Yep, and Anakin all the extra keywords and functions to it.. it's pretty complete. Quote Link to comment Share on other sites More sharing options...
anakin78z Posted September 29, 2003 Share Posted September 29, 2003 I'm trying to remember where that file is stored.... please stand by Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted November 13, 2003 Share Posted November 13, 2003 Marc said: I think filthy.... er.... geriatric.... er... horribl.... er....I think vi would win. Marc Sheesh! Who *cares* what kind V I M of editor one uses!!?!?? You know; there are very few V I M things that really bother me in life, but I gotta tell ya, these V I M silly, adolescent wars about which stinking V I M editor is better..... I mean COME ON, PEOPLE!!! V I M Just use whatever suits the job at hand, and get ON V I M WITH YOUR LIVES, FERCHRISSAKES!... V I M "geriatric" is pretty good, though, I gotta admit Quote Link to comment Share on other sites More sharing options...
athomas Posted November 13, 2003 Share Posted November 13, 2003 I'm myself a Nedit guy, got the rib, sl, mel highlighting trade for vex. Also Jason, have you found a way to keep multiple files open in one window? Cheers Andre Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted November 14, 2003 Share Posted November 14, 2003 athomas said: I'm myself a Nedit guy... Yeah; I just downloaded Nedit to check it out... looks pretty good (looks a lot like gvim ) .... I was kidding, by the way... Quote Link to comment Share on other sites More sharing options...
