Houdini 13 Wishlist
LaidlawFX
With the appearance of some cool plugins (BulletSOP and SimSOM, for example), I wonder if there is still sometimes the need to recompile a plugin for a specific houdini build. I had this issue very often with the HOT tool on houdini 11, now plugins seem to work for several builds. Did sidefx change something here? If it is a coincidence I would say it is on my wishlist for future.
- It would be great to have a way to load,unload or deactivate a plugin without restarting houdini.
- A even more unified simulation environment. Particle in DOPS still lack of some features and speed, and they could benefit from a bullet collision model
Any image format works as a GL texture map, and there is a display option to enable or disable mipmapping. Are you having an issue with this?
Yar, here is default mandril.rat on a sphere. Can't see it on linux - open suse, and windows 8.
Scratch head where did the upload button go.... lol... ok took me a little while found the upload button
Sphere...UV Texture - Polar Coordinates, Vertex... Material sop... Shopnet... constant gallery, $HFS/houdini/pic/Mandril.rat... in material sop /obj/sphere/shopnet1/constant
Mandril.hip
Edited by LaidlawFX
I didn't realize the list was this long, but these are the nodes with out icons... maybe by v14 they can get icons, but it would be cool. Maybe an icon contest? Have some free labor, idk, or else that is only what billion dollar studios do... it's gona be a while before that one gets ironed out.
Plus I know there is another similar list with docs, you don't realize you want them until you need them.
12.1.122
Sops
AttribCast
AttribFade-Subnet
ClothRefine -subnet
ConvertVolume
ExplodedView -Subnet
PolyDoctor
TimeWarp -Subnet
VolumeAnalysis
VolumeBlur
VolumeBreak
VolumeCompress
VolumeFeather
VolumeFromAttrib
VolumeMerge
VolumeReduce
VolumeReduce
VolumeResample
VolumeSDF
VolumeVelocity
VolumeVisualization
VoronoiFracture - subnet
VoronoiFracturePoint -subnet
VoronoiSplit
VortexForceAttribute - subnet
OBjects
None-Yeah!
Shop
BasicFlame
BasicLiquid
FluidFire
SpriteFog
Ramp... this ones need to be upgraded in formatt
Vops - also these share too many contexts, like vopsop, volumevop, etc.
Albedo
AntiAliasedFlowNoise
AntiAliasedRampParameter
Atan2
Bias
BurlapPattern
Checkered
ColorCorrection
ColorTransform
Composite
ComputeTangent
ConserveEnergy - Soo important
Contour
Cosine
Crackle
CurlNoise
CurlNoise2D
CVEXShader
DampenedNoise
Decal
DelayedLoadProcedural
DensityToOpacity
DirectLighting - kind of useful
DualAntiAliasedRamp
DualRest
DualRestSolver
EigenValues
FieldName
FieldParameter
FilterPulseTrain
FilterWidth
FitRangeUnclamped
FlowNoise
Foamy
FromNDC
FurGuideGlobalVariables
FurGuideOutputVariablesandParameters
FurProcedural
FurSkinGlobalVariables
FurSkinOuputVariablesandParameters
Fuzzy
Gain
GatherLoop
GetAttribute
GetBlurP
GetPrimitiveID
Glass
HairDiffuse
HairModel
HairNormal
HairSpecular
Image3DIsoTextureProcedural
Image3DVolumeProcedural
IndirectLigthing - Another Oh so important one
InstanceWithHscriptProcedural
IntegerToVector
IsFinite
isNAN
JitteredHairNormal
Lamberts
Limits
Logarithm
Matrix3toMatrix4
Matrix4toMatrix3
NeighbourCountFromFIle
NeighbourFromFile
NormalFalloff
OrenNayer
PhysicallyBasedDiffuse
PhysicallyBasedHair(PrimaryReflection)
PhysicallyBasedHair(SecondaryReflection)
PhysicallyBasedHair(Transmission)
PhysicallyBasedPhaseFunction
PhysicallyBasedSpecular
PointCloudImportByIndex
PointCloudNumFound
PointCloudWrite
PointInstanceProcedural
Properties
PyroBlackBody
PyroColorCorrect
PyroColorModel
PyroColorVolume
PyroColorDensity
PyroDisplace
PyroField
PyroFieldTweaks
PyroFieldNoise-op
PyroNoise
PyroNoiseSpace
PyroShade
RampFilter
RenderState
RunExternalProgramProcedural
Sine
SoftClip
SpecularSheen
SpriteProcedural
SurfaceColor
SwitchLightingBSDF
SwizzleVector
SwizzleVector4
Tangent
Trace
Transpose
TypeConvert
TypeConvertImplementation
TypedTwoWaySwitch
TypedTwoWaySwitchImp
UnifiedNoise
UVPosition
UVcoords
VectorCast
VEXVolumeProcedural
VolumeGradientFromFile
VolumeIndexFromFile
VolumeIndexToPositionFromFile
VolumeResolutionFromFile
VolumeSampleFromFile
VolumeVopGlobalParameters
VolumeVopOutput
VOPForceGlobal
VOPForceOutput
Woven
Cop2
VOPCop2Filter
VOPCop2Generator
That's a pretty long list man. I couldn't help but notice a couple VOPs that has no help anywhere:
TypeConvert
TypedTwoWaySwitch
Anyone knows what these are supposed to do? Perhaps operators that are intended to be hidden/obsolete?
TypeConvert
TypedTwoWaySwitch
My uneducated guess is that they're intended to be for use by Pyro only. But of course, these were created before we had the ability to hide nodes within the HDA.
I don't know if other apps have this but Cinema 4D have preview of your animation path in viewport that you can modify also in viewport. Something like follow path where you can modify curve but Cinema does it also for normal keyframe animation. You don't have to go to ChannelEditor to tweak movement.
Looks like 12.5 is also about things that didn't manage to get into 12.0. New viewport is getting back into its shape with this realize too. Interesting comeback is a render hook allowing to modify and/or replace built-in OGL renderer. There is an example in HDK of custom decorator which does exactly that: renders object path in a viewport showing also a path vector and shades path according to object speed.
I think the oglRop needs some love, it should behave the same as the flipbook tool from the viewport, for example background image, motionblur, Cameramask and MaskOverlay, it would be very handy to just run some different sims and playblasting them, right after they are finished.
In the documentation for vops show some imagery.
All the noise patterns and their distinguishing features. Filter Pulse train, there are dozens of nodes that can have one to one rendered patterns on grids.
Some like Conserve energy may be a little weird, but if you A B a simple example with and with out it. It'll make it click alot.
Fresnel sis soo easy to show, it's not a pattern but a render would show wonders. Maybe a little graphic diagram.
When the help docs are useful then people will use them.
Don't have the programmers make the pictures and worry about prettying it up, higher a real graphic designer maybe a couple of them. Programmer just need to add the useful info.
