SpencerL Posted December 4, 2012 Share Posted December 4, 2012 ESC key to instantaneously interrupt in SOPs and POPs similar to how it currently does in DOPs. Quote Link to comment Share on other sites More sharing options...
symek Posted December 4, 2012 Share Posted December 4, 2012 This could be a issue tied with the ogl support of the shaders. In programs like vue, modo, or zbrush your shader to viewport connections are very direct, locked in so they can't be broken or moded, OpenCL vex virtual machine would solve that problem . Seriously, quite a subset of vex is compile-able with GLSL, most noises, standard (non-pbr) lighting models, math, textures, which is enough to have an additional port in surfaceOutput for OGL. It's would be an user responsibility to wires things OGL can handle. (Something like a context switch would be handy too). 3 Quote Link to comment Share on other sites More sharing options...
Korhon Posted December 5, 2012 Share Posted December 5, 2012 ESC key to instantaneously interrupt in SOPs and POPs similar to how it currently does in DOPs. Yes please!! Quote Link to comment Share on other sites More sharing options...
symek Posted December 5, 2012 Share Posted December 5, 2012 Yes please!! You wimps! (it seems like interruption is done on per Sop basis by guarding expensive parts with some sort of UT_AutoInterrupt.* - which means either it doesn't work as expected, or it has to be used more often, ...or we need multi-threaded GUI...). 1 Quote Link to comment Share on other sites More sharing options...
sliver Posted December 9, 2012 Share Posted December 9, 2012 (edited) May be the most important for us : It should not be purchased by Autodesk Edited December 9, 2012 by sliver 1 Quote Link to comment Share on other sites More sharing options...
zarti Posted December 14, 2012 Share Posted December 14, 2012 ' wireless ' vop nodes .. .cheers Quote Link to comment Share on other sites More sharing options...
jonp Posted December 19, 2012 Share Posted December 19, 2012 "Detail" attributes in COPS that can then be worked with in VOPS, then exported to images as metadata. Quote Link to comment Share on other sites More sharing options...
3__ Posted December 21, 2012 Share Posted December 21, 2012 ' wireless ' vop nodes .. Like this? http://web.archive.org/web/20110722200545/http://kk.kema.at/files/gfx/werk2.jpg Quote Link to comment Share on other sites More sharing options...
zarti Posted December 21, 2012 Share Posted December 21, 2012 not sure what that image represents but here is what i meant with ' wireless ' : something similar with ObjectMerge_SOP when it is referring to any node within the same SOP network . so , in VOP contexts , there wdnt be necessary to drop 3 , 4 or more position_VOPs . but just one instead and referring to its value through a ' wireless ' input parameter . or for cases when we drop only one position_VOP and extend its connections into 3 , 4 or more other vop nodes ( usually far from the source vop node ) . less wires .. =) p.s.: initially i was ' inspired ' by WirelessLink tool found in Digital Fusion . in there , it acts more like ObjectMerge_SOP but i think a similar ' technology ' wd be very helpful in VOPs context . esp in SOP and SHOP states .. .cheers Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted December 22, 2012 Author Share Posted December 22, 2012 (edited) not sure what that image represents but here is what i meant with ' wireless ' : something similar with ObjectMerge_SOP when it is referring to any node within the same SOP network . so , in VOP contexts , there wdnt be necessary to drop 3 , 4 or more position_VOPs . but just one instead and referring to its value through a ' wireless ' input parameter . or for cases when we drop only one position_VOP and extend its connections into 3 , 4 or more other vop nodes ( usually far from the source vop node ) . less wires .. =) p.s.: initially i was ' inspired ' by WirelessLink tool found in Digital Fusion . in there , it acts more like ObjectMerge_SOP but i think a similar ' technology ' wd be very helpful in VOPs context . esp in SOP and SHOP states .. .cheers I know this isn't exactly what you want, but for cleanliness you can drop four position vops in front of each connection so you don't have wires running across the screen from one position vop. Mantra once it detect the first instance of a variable will store that. For instance subinputs to if nodes and subnets you can copy those a dozen times instead of using just one. Albeit a more friendly wireless method linking structs and nodes would be preferable. Setting a variable and calling it later with out wires can clean up some strange messiness. It does scare a lot of code writers from vops to see massive spider webs. Edited December 22, 2012 by LaidlawFX Quote Link to comment Share on other sites More sharing options...
ikarus Posted January 3, 2013 Share Posted January 3, 2013 particle fluid surface needs to be able to output a field Quote Link to comment Share on other sites More sharing options...
SpencerL Posted January 10, 2013 Share Posted January 10, 2013 Particle Fluid Surface SOP to have the option of using a Marching Tiles surfacing algorithm instead of the Marching Cubes currently used. Quote Link to comment Share on other sites More sharing options...
Macha Posted January 14, 2013 Share Posted January 14, 2013 I'd like to see a better build in code editor. It would already help if it wouldn't pop up in a separate window but instead reside in the parameter pane. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted January 15, 2013 Share Posted January 15, 2013 When is all this supposed to happen? In March I assume? Big thanks to SESI developers in advance Quote Link to comment Share on other sites More sharing options...
Solitude Posted January 15, 2013 Share Posted January 15, 2013 particle fluid surface needs to be able to output a field I requested (last May) that it outputs the field pre and post filtering in RFE ID #48420. An alternative if you have it, is using Openvdb, since you have direct access to the fields being used to create the mesh from the particles. Quote Link to comment Share on other sites More sharing options...
magneto Posted January 19, 2013 Share Posted January 19, 2013 Is Convex Hull SOP out of question for this round? Quote Link to comment Share on other sites More sharing options...
SpencerL Posted January 19, 2013 Share Posted January 19, 2013 Is Convex Hull SOP out of question for this round? It already exists....tetrahedralize SOP Quote Link to comment Share on other sites More sharing options...
magneto Posted January 19, 2013 Share Posted January 19, 2013 It already exists....tetrahedralize SOP Not really. The algorithm used in Tetrahedralize SOP does not scale well. It takes 15s for 100k points on my PC. I meant a SOP that uses a dedicated convex hull algorithm like qhull or cGAL's convex hull. Quote Link to comment Share on other sites More sharing options...
Solitude Posted January 19, 2013 Share Posted January 19, 2013 Not really. The algorithm used in Tetrahedralize SOP does not scale well. It takes 15s for 100k points on my PC. I meant a SOP that uses a dedicated convex hull algorithm like qhull or cGAL's convex hull. Presumably they are already using bullet's convex hull generation in dops -- I wonder if they can transfer that to a sop? 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted January 19, 2013 Share Posted January 19, 2013 I never used Bullet yet. Does Bullet have its own convex hull generation tools? I just tried adding a 100k points object as an RBD Object using Bullet's "As-Is" with "Polygons as Convex Hulls" option which seems defaults, and Houdini UI froze when I switched to DOPs for about 10 seconds. I wonder if it's actually using Tetrahedralize's convex hull code Quote Link to comment Share on other sites More sharing options...
